SC10 4x4 Thread
Tore my truck down to last screw last night. I bought one used, got a good price so i can sink plenty of $ in it and upgrade it to how i like it.
Anyway, i noticed the diffs and the interior of the case is all full of the diff grease. It really bogged down the rotation of the drive line. So is there anyway to keep the diff grease contained in the diff? or did they use to much and it bleeds out all over the place?
Thanks, Krom.
Thanks, Krom.
only 3/4 full will help the oil stay inside
25 to 30 k front diff
5 to 7k rear
Wow interesting, seems like it really bogs the trans down, free spin wise.
25k to 30k diff grease in the front?
OK, will give it all a try, sounds like i may buy a couple xtra trans from ebay and swap em in and out maybe.
Thanks, Krom.
kromulous
oil only goes into the diff cases , leave the transmission cases dry .
Extra transmission case not needed,spare diff cases maybe
Dup
Tech Legend
Got it, thanks all, more questions to follow LOL.
So far i like it, cant wait to run it, never owned anything 4 wheel drive, and in all these years.
Krom.
Krom.
Tech Legend
Its a fun vehicle for sure!
They are specific to the RC Shox center diff for the SC10 4x4. They adjust the diff action. See link below:
http://www.rcshox.com/sc1044-center-dif-v2/
I want to get one to try it out someday. I hear this is one of the key upgrades for this vehicle. More pins means stiffer action much like thicker fluid in a standard gear diff.
Tech Legend
I put 60k in the front. Works good
I try to search, but didn't find anything. After I put the spur gear on and tightened the clutch per the instruction, I cannot turn the spur gear. Am I doing something wrong?
Found the problem. One of the screws for the motor plate was too long. It was grinding the back of the pulley.
1 is a different length to the other two.
Take all three out and use the manual to put them in the right holes.
Don't do them up tight. Nip them up and check the diff still rotates freely.
If you crank them up you will crush the gearbox and bind it up.
