Like Tree5Likes
SC10 4x4 Thread
Old 01-12-2013 | 09:00 PM
  #32161
Cain's Avatar
Tech Legend
no prob. wish I could help more but don't have the vehicle to look at. Good thing, the 3.5 degree setting was pretty much money on anything where you wanted better rear bite. AE could make a killing making a similar item.
Cain is offline
Old 01-12-2013 | 11:05 PM
  #32162
Wild Cherry's Avatar
Tech Legend
Default N/w Show Down Seriers
dup
Wild Cherry is offline
Old 01-12-2013 | 11:10 PM
  #32163
Tech Legend
Sc4x4 class
Reedy 550 Sonic brings victory for Mike Brown and his Ae Pro-Lite
Happen today in the 3rd round of our racing series touring our best N/w indoor tracks ...
also ....
2nd place used a Reedy Sonic 550
and again....
3rd place used the Reedy 550
Watched the guys with the 4 poles,
they were quite a bit slower out of the hole compared to theBig Block Sonic's...
Also discuss tonight with the
local Tenkin rep and he told me the 550 motor has more torque because of its larger rotor compared to the 4 pole ...
Old 01-13-2013 | 02:50 AM
  #32164
Originally Posted by Cody227
broke my third servo saver in a half year today... i have to do sth. against it. I thought about locking up the hole servo saver and then use a cheap drop-on-servo-saver like this one: http://www.amainhobbies.com/product_...ver-Airtronics has anyone tried sth. like that?
no one?
Cody227 is offline
Old 01-13-2013 | 06:49 AM
  #32165
fq06's Avatar
no one?
Don't run that thing.
Every once in a blue moon someone will post about a broken servo saver and most have it adjusted way too tight.
Get a new stock part and adjust saver tension to stock setting.
If you really want to make it bomb proof (but not necessary) get the strc bell crank & rack.
fq06 is offline
Old 01-13-2013 | 07:32 AM
  #32166
98NYFINESTVETTE's Avatar
I broke 2 because they were to tight. I am still on my third replacement. I did not make it so tight and it has been well. I drive it hard.
AE SC: What pinion size are you using? I read that you are not able to pull out of turn hard enough.
98NYFINESTVETTE is offline
Old 01-13-2013 | 07:47 AM
  #32167
Tech Legend
no one?
I use the stock saver but I also glue it together like we do on the B4 & T-4...
The plastic it is made of flex's enough to act like a saver when glued .
Improves the steering response & feel .
Tip
Use a high grade servo with metal gear if you do it this way....
Old 01-13-2013 | 08:24 AM
  #32168
Cain's Avatar
Tech Legend
You have a part number for the big block sonics you saw used? Reason I ask is that the sonic 550s look like there rotors are 12.5mm (looking at the replacement rotor) spec:
http://www.teamassociated.com/reedy/parts/details/970/
Tekin's Pro4's are 18.5mm ...
http://www.teamtekin.com/Pro4.html
http://www3.towerhobbies.com/cgi-bin...?&I=LXBWVH&P=7
MOTOR P/N TURNS VOLTAGE KV ROTOR
Redline PRO4 4600 TT2500 1Y 2S 4600 18.5mm
Redline PRO4 4000 TT2501 2D 2S 4000 18.5mm
Redline PRO4 3300 TT2502 2.5D 2S-3S 3300 18.5mm
Or, for those that work better visually:
Reedy
Tekin
Yeah, I think the same thing too concerning the larger rotor making more torque.
Gee Cain , When I watch the guys with the 4 poles ?
they were quite a bit slower out of the hole compared to the Reedy 550...
Tell your Reedy rep what I saw today...
I am sure you can mention to him as I think you have heard of him.
Rick Hohwart ring a bell?
He is who I asked concerning the torque comparisons, advised me about the initial torque differences, and his honesty has me interested in picking up a Reedy Sonic for outdoor or medium track usage to try out in comparison since the conditions I am running on would see more benefit with the Pro4 mainly do to the more initial torque it makes. The fact though that the overall powerband and drag brake feel is better in his opinion has me very interested.
He definitely is a real asset to Team Associated, that should clone him.
Cain is offline
Old 01-13-2013 | 08:35 AM
  #32169
Tech Legend
Cain
Rick reads the threads , and most likely already seen Mike Brown's results from yesterday ....
Tell him this will yeah ?
We are all switching to the Pro-Lite .......
Ha Ha Ha
Cept of course the Team Drivers, they have to & ordered to use the Sc10 4x4 .
Old 01-13-2013 | 09:01 AM
  #32170
Cain's Avatar
Tech Legend
Yeah, I know he does, one of his great traits.
Cain is offline
Old 01-13-2013 | 09:10 AM
  #32171
So I'm about to bite the bullet on a SC10 4x4 contrary to what almost everybody at my local track says, but can't seem to find what motor combo to use for it. I've read the beginning of the thread about 50 pages in, but can't go through the 2100+ you guys have lol.
What is the current top 3 setups for motor/esc combo? I read a lot about the MMP + 1050, but is there something better now compared to when this thread started?
Also, what made you guys choose this truck over the Losi or Durango? My entire track is pushing the Losi on me... Even the one guy who runs fast with the SC10 4x4 is suggesting I don't go that route. I have a few things in my shopping cart, jus don't know which to actully pull the trigger on.
I've heard mixed reviews on the RX8 system, but if it IS the best I have no issue getting it. As for motors, I'm reading a bunch of stuff about different rotors etc, is there not a motor I can jus buy and throw in?
Thanks guys!
CaseyDDR is offline
Old 01-13-2013 | 09:11 AM
  #32172
Tech Legend
Yeah , Way back in the 90's at the REEDY ?
I took a old White shell he toss away & used with great success...
I'm a big fan of him....
Old 01-13-2013 | 09:28 AM
  #32173
CraigMBA's Avatar
Peak.
CraigMBA is offline
Old 01-13-2013 | 09:45 AM
  #32174
Tech Legend
Cain , know your looking at other rides ...
The Pro-lite is the one you should look at the hardest ...
Has the losi , Durango , conversions, ect covered ....
Way better looking on the track then the rest , even a racer like you would agree, its kinda obvious ...
Mike insisted on me to test run his , his runs a tight line like a B44.....
Stay tune on the Pro-lite thread everyone...
I will be sharing how to set-up the Pro-Lite and the battle will rage on .. ...
Old 01-13-2013 | 10:16 AM
  #32175
Cain's Avatar
Tech Legend
May get to see one up close, or someone around here as the sparrowhawk equivalent to get a feel. Though, I would want a pro version. But i think it does have potential personally, reminds me of the dominusi in way.
But as I have said, parts sharing is one of the big things I am looking at with the SCT410 and the EB48, and my initial impression of the EB48 at least is its very high quality and has the layout I expect, so hoping the SCT410 shares those traits and does the things I need.
However, if not, will move on and who knows, could be back with the sc10 4x4 since I have been happy with it after putting the mods on it.
Cain is offline
