Like Tree5Likes
SC10 4x4 Thread
Old 01-11-2013 | 10:31 AM
  #32116
Cain's Avatar
Tech Legend
Originally Posted by ryanpatrickgore
I don't think there is a smoother motor out there go 4x than the reedy 550 4.5.
It's a gem for sure
What is your experience as far as torque goes in comparison to a Pro4 motor?
Cain is offline
Old 01-11-2013 | 10:32 AM
  #32117
Wild Cherry's Avatar
Tech Legend
Cain , I agree many
that do not try, test or even have Ae help .
the 4 pole is a 540 can so a 550 ?
Has more....
Biggest difference between?
Is the weight ....
Wild Cherry is offline
Old 01-11-2013 | 10:40 AM
  #32118
Cain's Avatar
Tech Legend
Originally Posted by Wild Cherry
Cain , I agree many
Has more....
Looking forward to seeing one of these Reedy's in person to compare, but from what I have seen from the Tekin and Novaks without the larger rotor, the 540 4 poles have more torque. may not be as smooth though.
Cain is offline
Old 01-11-2013 | 10:46 AM
  #32119
Tech Legend
Default Torque Curves
540 4 pole has way more torque then a 540 2 pole
550 2 pole has even more torque the a 540 4 pole
Old 01-11-2013 | 10:51 AM
  #32120
Cain's Avatar
Tech Legend
unfortunately, that is not what I saw in actual real world use with the Tekin 550 in several configurations or the Novak 550 (stock rotor, not the 13mm). It is what it is WC, on the extremely tight indoor carpet tracks I run on, torque in king. Guys are running Pro4 style motors in there 2wd stadium trucks to get that instance punch they need over the jumps coming off 180s where you are at a dead stop.
Can't comment on the Reedy however, never seen one used around these parts but doens't mean that it hasn't been. Will have to check around, but the usual "its smooth" nomenclature means "it doesn't have as much instant torque'.
Cain is offline
Old 01-11-2013 | 11:00 AM
  #32121
Tech Legend
Originally Posted by Cain
unfortunately, that is not what I saw in actual real world use with the Tekin 550 in several configurations or the Novak 550 (stock rotor, not the 13mm). It is what it is WC.
Go ahead & test motor's some more then....
I can wait ....
Old 01-11-2013 | 11:07 AM
  #32122
Cain's Avatar
Tech Legend
I can wait ....
Same here with the Center Diff ...
Cain is offline
Old 01-11-2013 | 11:13 AM
  #32123
Tech Legend
Back to that crap ....
If your so expert ?
You could prove it works as Cameron ( Mantis best trusted driver) showed me it don't ...
Old 01-11-2013 | 11:19 AM
  #32124
Cain's Avatar
Tech Legend
If your so expert ?
As far as the Center diff working, yes, it does. As for Cameron's issues, I talked with him about what really happened, and it was no issue with the Center Diff as you already know but choose to ignore. It is what it is WC.
Cain is offline
Old 01-11-2013 | 11:26 AM
  #32125
Tech Legend
O please tell us what really happen ....
If there was no issue why did have to remove to get good laps like he did achieve with the VTS..
I drove his truck , watched in person carefully everything he did ...
His pit was about 10 ft away from mind ...
Up O !
Sounding like another engineer story....
Old 01-11-2013 | 11:52 AM
  #32126
Cain's Avatar
Tech Legend
Up O !
I let you do that WC ...
Hey ! Guess you don't believe me , no big for me ...
Saw motor or ESC issues during each qualifier & main...
I think a fail safe was being tripped , every heat it kicked in ... don't know for sure , ask um ...
O that's right you did ask , sorry....
or this one?
Cain
I watched every run he made , had motor or ESC problems a plenty ..
Talk to um too ...
Told um was not to be disappointed & not to give up the Sc10.
But that truck itself was great.
No problems with how it drove after he switched the set-up .
It had great traction , jumped the siszor's just fine ...
In fact the truck never miss behaved when I drove it , that was for about 8 or so laps .
Told um not to change it ...
lets here your story.....
Which jives with what he said when I asked, that he was hunting essentially for anything to fix the issue.
But hey ... don't let the truth or your own words get in the way ...
Cain is offline
Old 01-11-2013 | 11:56 AM
  #32127
dominick i.'s Avatar
Suspended
back to racing fellas.
any opinions on whether to use overdrive or not.
I am currently using it and may switch back to regular pulley to see how handling changes.
dominick i. is offline
Old 01-11-2013 | 12:03 PM
  #32128
Tech Legend
Cain
The Truth is ?
You only have a 2nd hand engineer story ...
Old 01-11-2013 | 12:16 PM
  #32129
Cain's Avatar
Tech Legend
been hearing good things about it , give it a shot and see what you think.
Cain
The Truth is ?
aren't all stories second hand WC unless from the person telling it?
Food for though ...
Cain is offline
Old 01-11-2013 | 12:21 PM
  #32130
MRCCC's Avatar
So I logged on this morning to catch up on the threads and I just got back home from work and noticed about two new pages of back and forth from Cain to WC...LOL love this thread.. However I have to thank you both for taking the time to enlighten us common weekend part time racers.
MRCCC is offline
