Like Tree5Likes
SC10 4x4 Thread
Old 06-13-2011 | 04:36 PM
  #3166
BlueGlowBoy's Avatar
Originally Posted by Waldo183
Any thoughts on how to keep the CVD pins in the rear from falling out?
Odd, I haven't had that problem at all on this truck...about 20 packs in, many times I've had the right rear wheel off so that I could re-gear/re-mesh/adjust slipper and belt tension....never had the pin even wiggle loose...
I've seen some trucks put a small spring inside the diff outdrives to keep some tension pushing the CVD outwards... I even used a small piece of fuel tubing on my rally car to keep the bones from popping out...
BlueGlowBoy is offline
Old 06-13-2011 | 04:39 PM
  #3167
ilanstylz's Avatar
Whos running their sc10 with the castle sct esc (not the mmp, just to clarify), I remember reading it will work if you place it up high or add vents to the body.... I was just wondering for those running this esc what are your temps on the esc say after a 10-15 min run? Thanks
ilanstylz is offline
Old 06-13-2011 | 04:40 PM
  #3168
JS's Avatar
JS
Originally Posted by symmetricon
Have any of you guys balanced all four corners of your truck??? Running a gens ace 5000mah 40c battery, with a hobbywing sc10 esc/castle 1410, the front left corner needed a little over 2oz to get it close!!??
Tomorrow I'll be testing the new dual stage pistons
Thanks Mantis
Thanks for the weight info Symmetricon
I am running a Gens Ace 5000/50c with an RX8 and 1410. Also using the RX box with a SR3100 spektrum rx.
Did a little research and found that the SC10 ESC is 88g and the RX8 is at 76g. There is also a 10g difference between the Gens Ace 40c and 50c lipos.
I will test with 2oz or 2.25oz and see how it goes.
JS is offline
Old 06-13-2011 | 05:01 PM
  #3169
FrancoisTX's Avatar
Default Sway bar
Hey guys,
I have received my front sway bar from AE today......
I ll going to try friday.
FrancoisTX is offline
Old 06-13-2011 | 05:06 PM
  #3170
FrancoisTX's Avatar
Default Sway bar
Hey guys,
Old 06-13-2011 | 05:23 PM
  #3171
It works fine if you add the fan. So instead of putting the fan in the motor, just put it on the ESC. Mine comes down at 120' with the fan. Without the fan, it hits high temp cutoff.
I'm running mine 32P with 16T pinion.
BoneDoc is offline
Old 06-13-2011 | 05:24 PM
  #3172
JS's Avatar
JS
Maybe using the Tekno Hex upgrade will fix this?
Everytime I took the wheels out - the stock plastic wheel hexes would come out. You would have to snap it back in so that the CVD pins would not fall out.
After upgrading to the Tekno Alu Hex - the hex would now stay put and I would not have to worry about the hex loosening up causing the pins to fall out.
I always hated plastic wheel hexes anyway - I always upgraded to aluminum clamping hex's on all of my rigs (if available).
JS is offline
Old 06-13-2011 | 05:27 PM
  #3173
symmetricon's Avatar
Hey Francios, I'll be at Mikes on friday and plan on racing. Are you gonna be racing too? Are you starting to get it dialed in?
symmetricon is offline
Old 06-13-2011 | 05:47 PM
  #3174
This is a real design flaw. Use some Shoe Goo. After you put the pins in use a little dab on either end to kind of seal the ends. Also, put some on your hex pins before popping the hexes on After doing this and running dirt a few times everything seems nice and "sticky".
I'd be interested to know what either people are doing with their slippers? How tight or loose or you running them?
longbeard is offline
Old 06-13-2011 | 05:56 PM
  #3175
JS's Avatar
JS
Default 32P vs 48P with RX8 and 1410
Comparing 16/62 32P and 24/93 48P (both with 9.95 FDR).
Which would perform better -32P or 48P?
Or would they be exactly the same in speed, bottom end, run time, etc?
What would be the advantage and disadvantage with either setup?
JS is offline
Old 06-13-2011 | 06:10 PM
  #3176
JEFFs SC10's Avatar
JS if they are the same FDR why would one be better than the other?
JEFFs SC10 is offline
Old 06-13-2011 | 06:18 PM
  #3177
JS's Avatar
JS
I'm thinking that the 32P will be stronger and louder while the 48P would be quieter with more gearing options.
Curious if there are any other differences.
JS is offline
Old 06-13-2011 | 06:23 PM
  #3178
JEFFs SC10's Avatar
32p will be stronger, not sure about louder cause they are plastic gears.
If its the same gear ratio pinion to spur, one will not outperform the other. They are equal.
Old 06-13-2011 | 07:00 PM
  #3179
ffpm46's Avatar
Does anyone know why AE site doesn't list the Rear Sway Bar anymore?
I see there is a pic of the from Bars.
ffpm46 is offline
Old 06-13-2011 | 07:12 PM
  #3180
I just ran my Sidewinder SCT/1410, 3800KV combo yesterday and was really pleased with it! Mounted as per kit instructions with the included fan ON THE ESC. I didn't have a temp gun with me but my reasonably well-calibrated finger suggested it never went over about 100-120 degrees. This was with 15/62 gearing. So far I'm really impressed for <$100!
Cheers,
Mike
Hyper_Mike is offline
