Like Tree5Likes
SC10 4x4 Thread
Old 11-30-2012 | 09:29 AM
  #31426
killermmn's Avatar
a other question,do the ft kits have the hole in the frame for saddle pack convertion and for the diff houssing do i need to add a other shim off 0.2mm are just one 0.2mm?
sorry english is not my primary language!!
killermmn is offline
Old 11-30-2012 | 09:39 AM
  #31427
Cain's Avatar
Tech Legend
factory team kit comes with the saddle pack conversion.
As for the 8mm mod ...
Give it a try yourself and see what you think. I and others have found that it increases rear traction. The inner ball stud position in my opinion is what when doing the 8mm mod cuts down on the traction rolling that this can cause. If you are traction rolling and want that to stop, try raising the rear inner ball stud FIRST before the mod.
But, that is my opinion, give it a shot yourself and see.
Cain is offline
Old 11-30-2012 | 10:56 AM
  #31428
I'm sure this is here some where but...I just picked up one of these from a guy at the track and I am wondering what tools I need. Seems nothing from my ft sc10 crosses over. What sizes are the most common tha I should get first?
Thanks,
Mark
mark in wi is offline
Old 11-30-2012 | 11:07 AM
  #31429
FRONTI3R's Avatar
Visit the first post of this thread Mark. Old but good info. there. The tools are ALL metric and listed on the first post.
FRONTI3R is offline
Old 11-30-2012 | 11:09 AM
  #31430
Thanks!!
Old 11-30-2012 | 04:59 PM
  #31431
brocsizzle's Avatar
In my opinion the truck as a stocker has a very high roll center. This makes the truck unpredictable and darty, especially during rough sections of a track. You can very easily over drive it if you have a less than smooth throttle finger. Often I'd ask for way more than the truck was willing to give me, usually resulting in a traction roll or crash. After the +8mm camber mod, the rear is way more planted and I can drive the truck a lot harder-I mean ALOT harder. It's way more forgiving, and let's you charge the jumps more aggressively. Not to mention I picked up almost a full sec per lap.
Anyone ever heard an AE truck go by while marshalling that was whisper quiet? I'm trying to get mine to quiet down. I think the drivetrain by nature is not too noisy, so what's the secret? I'm running a fantom 6.5 with a Novak havoc pro sc. It's the motors I think that make all the noise in these trucks, I just bought a reedy sonic 5.5 thinking it'd be quiet, but still sounds like a meat grinder. What's the smoothest motor out there that'll make this thing whisper quiet. Any ideas? Thanks.
brocsizzle is offline
Old 11-30-2012 | 08:04 PM
  #31432
ryanpatrickgore's Avatar
I think you should go the opposite direction maybe.. Go as loud as possible to scare people out of the way. You could be the "intimidator" lol
ryanpatrickgore is offline
Old 11-30-2012 | 09:54 PM
  #31433
Acill's Avatar
Mine is whisper quiet. I have a full set of ceramic bearings, even in my RC Shox center diff mod. I have also used a product called jigaloo on all the metal surfaces to smooth out the friction, the plastics are sprayed with it too. Its a dry film spray lube. Awesome stuff.
Acill is offline
Old 11-30-2012 | 10:06 PM
  #31434
Default pro 4
Taking apart a pro4 for the first time. Is this some sort of balancing putty or compacted dust on the inside lip of the rotor?
associatevalley is offline
Old 12-01-2012 | 04:29 AM
  #31435
Acill's Avatar
EW, mine is shiny and clean. Id say clean that out.
Acill is offline
Old 12-01-2012 | 06:33 AM
  #31436
keddy's Avatar
It's balance putty 100%, mines got a few as well. Take that off and you're gunna have a bad time.
keddy is offline
Old 12-01-2012 | 08:01 AM
  #31437
Acill's Avatar
I must not be looking at the same thing then.
Acill is offline
  #31438
Originally Posted by Prostreet314
I have 2 v1 ball diffs sitting in a bag (it was barely used and I lost 2 of the balls so I ordered a whole extra diff) I'll send to you if you pay the shipping. Then all you'll need is the v2 upgrade kit from mantis which he sells for 15 bucks. Let me know.
As for the exotek chassis, yes the radio box and all other pieces for the stock chassis fit into it. And yes the nerf bar screw holes on the exotek chassi are to shallow so you will need 4 3x10 cap head screws. Also the 3x14 chassis screw holes are too shallow as well so use the 3x12s from the nerf bars for them instead.
Anyone interested in a v1 exotek chassis? Let me know
I keep getting surprised by how helpful and generous members are here. Just want to say thanks in advance
Ran my truck at the track for the first time.
I had the 2.0 sway bars on front and back. I don't know if it was wrong tire choice or swaybars but I didn't have any ability to turn sharply
I broke my 3.2 rear block after my 8th high speed impact on the pipe
Hobby store had more in stock. I will try the tire of choice for my track sunday. Its a packed damp clay track, that very technical and I need to turn alot. Any sway bar suggestions? My shocks worked awesome I landed hard a few times and the shocks took the abuse great, in general I beat the hell out of this truck and minus one broken part nothing else was damaged. I hit a pipe so hard I ripped it anchors out lol.
AE SC10 4X4 is offline
Old 12-01-2012 | 09:57 AM
  #31439
CraigMBA's Avatar
What are you using for a servo?
CraigMBA is offline
Old 12-01-2012 | 11:44 AM
  #31440
CraigMBA's Avatar
Originally Posted by Wild Cherry
Plus 1
Just got yesterday , still have to install though ....
Big improvement ...
Hell yes it will be!
Same PN?
CraigMBA is offline
