SC10 4x4 Thread
Is the guy that runs RC shox a regular to this thread or is that the exotek guy? I don't see a " contact us" option on the RC shox Site and am looking to ask them what size spur comes with the center diff kit, and if the diff balls are the same size as ae ball diffs. (3/32). Looking to try the C diff out.
Oh and associatedvalley you have a pm
You've got it backward... the diffs ship with the 60 tooth spurs but you can get 62, and the balls are 4mm, not 3mm.
[email protected]
From past experience he should answer in a reasonable time (with a reasonable answer).
No, your right, that is what I was running indoor last (sticky track), outdoor I run one. Guess my mind was stuck on one cuz that's what I'm usually at in & out. 1° increments as you said.
If you go to the rcshox website there is an "email me" link that is addressed to:
[email protected]
[email protected]
Tech Legend
For that rear top shaft I got in that was bent, Got the car fully apart and it was just the threaded portion and I bent it back. Any issues with doing that someone has epxerienced or should I be good to go?
This IMO is one down side to running the center diff, lots of stress on the threads, and shaft, as there done up so tight.
I am assuming your running the ball diff?
Yeah, I bent mine as well but just bent it back. Hasn't caused me a problem yet but I do have a spare just in case.
took a 3 week break from the 4x4.. drove it last night just for fun and TQ'd.. couldn't believe it! truck felt like it was rails half the time.. not sure if it was the track or my truck.. i was running suburbs which i never do but seem to be hooking up.. currently running the BK set up..
I'm half joking, I figured you knew how to read the scale just fine. Your point is well made, though; it's a precise camber measurement.
Tech Legend
Push comes to shove, probably get a regular one.
I am attaching the loose track setup I used from those vids. hope it helps someone.
Transmission Lube
What, if anything, are people putting on the transmission gears before closing up the case?
I saw a thread which mentioned heavy shock oil, pledge. What about a touch of black grease or green slime?
I feel like I've used shock oil and Associated black grease in the past (not for the same rebuild) and it was okay, but want to hear some opinions from people.
And one last thing, no pressure, but I'm ready to close up the case and want to get cleaned up before the kids get up from their naps, so answer now SVP!
