Like Tree5Likes
SC10 4x4 Thread
Old 09-03-2012 | 10:52 AM
  #29161
Originally Posted by Wild Cherry
Will be endorsing the hell out of the AVID slipper system now ....
Have you tried one yet or just endorsing the hell out of it since some AE drivers are using it?
Actually asking honestly here as well as giving a bit of a jab since you typically will not endorse anything you have not tried yet. Especially if it is not AE. I have tried both versions of Marcus' slipper, the old stock slipper and the VTS with and without the Garo disks. I can tell you that the VTS with garos works great on the pavement but offers less stability than the v2 slipper on the looser stuff for me. Just wondering if you will put some time into this new slipper and report back with some results compared to the stock VTS or just say it is the bomb since other AE drivers are running it?
Thanks and please do report back on what you find.
AzFittin is offline
Old 09-03-2012 | 11:00 AM
  #29162
tom2tone's Avatar
R/C Tech Elite Member
Originally Posted by johnbugman
OK thanks guys for all the recommendations. Keep em coming (setups)
Agreed! I'm running 20f/7r with the stick pack. But I'm curious to see what the set ups are now with the FT kit.
tom2tone is offline
Old 09-03-2012 | 11:02 AM
  #29163
Wild Cherry's Avatar
Tech Legend
Originally Posted by sugs
On your 4x4? Avid doesn't list the AE SC10 4x4 as being compatible?
Pretty sure I will have to use the Ae rear drive plate with , but otherwise will be using soon .( AVID 87T spur & Robinson pinion)
Already used a AVID slipper for a few runs with my B4
Will order my AVIDs later this week...
And of course ...
Will tell everyone about how they performed for me after I get ....
Wild Cherry is offline
Old 09-03-2012 | 11:04 AM
  #29164
Jake S's Avatar
Originally Posted by vito
my esc is a novak gtb2 sport man made for a slash 4x4 . i tryed 15 tooth and the esc got hot motor was ok. iam at 12 62
how i set my gtb2 up. everything else on default. i also run a fan on mine, and run a 550 4.5 motor @ 62/12, no additional motor timing.
min brake to #5 (12%)
drag brake to #1 (0%)
min drive up to #5 (4%)
dead band to #1 (2%)
brake fq to #10 (13.7%)
Jake S is offline
Old 09-03-2012 | 11:06 AM
  #29165
vito's Avatar
its all stock settings i took the drag brake out
vito is offline
Old 09-03-2012 | 11:19 AM
  #29166
Jake S's Avatar
has no balls to get up to speed
i also had this issue one race day, found one of my pulley tensioners where binding, so i replaced a bearing... and almost magically i could triple alot easier.
so i would suggest taking your transmissions apart and cleaning them and checking belt tension as well as the tensioners.
even too tight of gear mesh can make it feel sluggish too.
Jake S is offline
Old 09-03-2012 | 11:20 AM
  #29167
ShortCourseOnly's Avatar
Which Hobby King ESC would your recommend? Which motor would you recommend?
I have a friend that needs a new ESC for a 4.5t 550 motor or higher.
ShortCourseOnly is offline
Old 09-03-2012 | 11:26 AM
  #29168
Going from 12t to 15t is a huge difference with that motor... try going up one tooth at a time. 13t may be all you need...and I would not go over 14t with that motor.
Sofa King is offline
Old 09-03-2012 | 11:36 AM
  #29169
Jake S's Avatar
if running a 540 4pole motor:
XERUN SCT PRO
http://www.hobbywing.com/product_show.asp?id=263
Nice Combo from them with a 4pole: (black)
http://www.hobbywing.com/product_show.asp?id=272
Jake S is offline
Old 09-03-2012 | 11:50 AM
  #29170
XERUN SCT PRO
I like these but where can you purchase them in Brazil? Most people are buying from Hobby King not Hobby Wing. They have Turnigy, Trackstar, and Hobby king brands. I have a Hobby King 30A sensorless speedo that is pretty good really but prefer sensored myself.
The Trackstar SCT ESC looks pretty good. I think it is sensorless though. See link below:
http://www.hobbyking.com/hobbyking/store/__22632__Turnigy_TrackStar_120A_Brushless_Short_Co urse_Truck_ESC.html
Old 09-03-2012 | 12:06 PM
  #29171
Jake S's Avatar
http://www.hobbywing.com/dealer.asp
Jake S is offline
Old 09-03-2012 | 12:54 PM
  #29172
I'm running the 120a Hobbywing ESC that can also run 1 cell. It's coping very well with my Tenshock motor. Very pleased.
Switching to the Avid slipper would mean changing all your spurs and making sure you have spares and do they not make a 32 pitch spur? I don't think a 48 pitch would last long on some of the big SC10 4x4 motors!
Beachbuggyphil is offline
Old 09-03-2012 | 01:42 PM
  #29173
Vegatron75's Avatar
Hey ? Surprise !!!!
Not using backward springs, aftermarket slipper pads & those 2 stage piston's ....
Won't ever do it !
Just rooting for the Champion ...
nothing wrong in that at all ....
Starting to prepare my Sc10 4x4 today...
Thinking of using Mayfields set-up this time .....
Also ordered me the new Slipper from AVID .....
Most of my teammates are using now ....
Matt I don't think I have made one post where I have been dissing him or his products ..
Originally Posted by ryanpatrickgore
All he said was mayfield did it without. Didn't say anything bad about the product. Just that rm did a good job with his stock kit.
Just saying.. play nice people no need to bully and gang up.
K mr. 29 posts.
No need to call names on here.
If you don't have something say... Don't say anything at all.
This dosnt contribute one bit to the thread
Yes , he makes sense and did have to resort to 8th grade name calling to make a point ..
Agreed. I think we need a few more options on this thread. Like a scarcasm button, and a cheeky button. Ect..
Not always easy to interpret the "tone" of text.
That's why we all need to keep it "light" in these forums.
hard to read all this stuff about wc because I know him and he's a truly nice guy. Will help out anybody at the track. Yes he does stir the pot but many of us do too.
Originally Posted by Jspfeiss
Shut up stupid!
JSp summed it up perfectly.... This thread is now totally worthless, everything that anyone needs to know was posted along time ago.
Now it's a 2-way circle jerk, WC and his stooge.... Have fun with all the bad tech and blatant nut swinging....
Vegatron75 is offline
Old 09-03-2012 | 02:00 PM
  #29174
ryanpatrickgore's Avatar
ryanpatrickgore is offline
Old 09-03-2012 | 03:33 PM
  #29175
+1
SC Shaun is offline
