Like Tree5Likes
SC10 4x4 Thread
Old 09-01-2012 | 11:59 PM
  #29086
Originally Posted by itchy b
Body would get heavy mighty quick with all the dirt flung at it
I was more referring to literally chucking the rubber off the wheel thus chucking the dirt.
SC Shaun is offline
Old 09-02-2012 | 05:58 AM
  #29087
Does anyone make the under tray for the truck with the chassis brace installed ?
Greg B is offline
Old 09-02-2012 | 06:08 AM
  #29088
dagsom's Avatar
I haven't seen one but I modded mine to fit with the brace.
http://www.rctech.net/forum/10938632-post26095.html or page 653
dagsom is offline
Old 09-02-2012 | 06:27 AM
  #29089
itchy b's Avatar
I like the outerwears for the sc10 4x4
Protects the electronics but lets it breath
itchy b is offline
Old 09-02-2012 | 07:06 AM
  #29090
tom2tone's Avatar
R/C Tech Elite Member
Thumbs up
Originally Posted by rip67vdub
Hey Guys,
My son and I are in the process of setting up our SC10s. I picked up a few Orion 6500 90c lipos here. However, my venom pro charger only charges @ 5A max. Is there any longevity or performance impact of charging my lipo @ 5A? Should I perhaps invest in a different charger that can support > 5A? Let me know your thoughts. Your help is greatly appreciated. Happy racing.
Other than it taking forever to charge, it does help the battery life to charge at lower amps. When you charge the battery at higher amps it does charge much faster but also can shorten the battery life. There are quite a few options when it comes to chargers. Most of it depends on what will suit you best and what's within your budget. I personally went over board and bought a Powerlab 8 which can charge up to 8s lipo, 40A and is 1344 watts.
http://www.amainhobbies.com/product_...-1344W-Combo-4
Also keep in mind, if you want to charge more than 5 or 6 amps. Most likely you will need a separate power supply. I've gone through quite a few chargers because of changing types of batteries. So my advice is to get the strongest charger you can afford. Therefore if you go into a higher cell or different chemistry of battery, you will have that option. Yes the price tag can be a little hard to swallow. But you will end up thanking yourself and saving yourself money in the end. I hope this helps and please feel free to pm me with any other questions.
tom2tone is offline
Old 09-02-2012 | 08:12 AM
  #29091
BorackBasher's Avatar
Originally Posted by Jake S
looks like Numedahl is the only big name in 4wd corr for associated, wonder if he has his old setup or has maifield's tweaks with the coupled
i was able to have a sneak peak at his truck while he wasnt around.. he's still running the c hub towers but from the looks of it it looked different from the normal "c" hub tower.. i bought the jconcepts A,B,C bag of carbon towers to try and make his set up closer to mine.. had about 7-8mm in the rear..
BorackBasher is offline
Old 09-02-2012 | 09:06 AM
  #29092
johnbugman's Avatar
Originally Posted by AzFittin
I am having a problem with my tires packing up with dirt so badly that I mine as well be running slicks. I have tried Cityblocks, Enduros, Trenchers, Tazers and even the stock tires and all have the same issue. I went towards the Cityblocks and Tazers since the track is hard and very loose (almost like pebbles on top) when it dries out and they seem to handle that pretty well. A long time ago I used to spray the tires down with PAM which helped huge on the 4 minute runs in 2wd buggy but it does nothing for this truck. Any suggestions?
ya I had the same problem at the last track I was at... the clay was waaaay to wet. anytire would pack up like this. the first 1/4 inch was soggy fresh clay was the problem. the truck is running holeshot 2.0's. the b44.1 is running calibers.
Attached Thumbnails SC10 4x4 Thread-img136-1-.jpg   SC10 4x4 Thread-img147.jpg
johnbugman is offline
Old 09-02-2012 | 09:10 AM
  #29093
vito's Avatar
need help guys i have a novak gbt2 esc and 550 4.5 trun motor at 12 62 gearing. i have no timeing at all the esc is at the stock settings. i got no get up and go its not bad ?
vito is offline
Old 09-02-2012 | 09:11 AM
  #29094
johnbugman's Avatar
Originally Posted by mHOUPS
Nice!! I did mine the exact same way a couple of weeks ago, it's nice & clean, I dig it.
The original "OG" setup.
Old 09-02-2012 | 09:31 AM
  #29095
johnbugman's Avatar
Default setup sheet.
new maifield setup sheet just came out on teamassociated.com.
Old 09-02-2012 | 09:41 AM
  #29096
Wild Cherry's Avatar
Tech Legend
Hey ? Surprise !!!!
Not using backward springs, aftermarket slipper pads & those 2 stage piston's ....
Wild Cherry is offline
Old 09-02-2012 | 09:43 AM
  #29097
vito's Avatar
can i add timeing at the motor?
vito is offline
Old 09-02-2012 | 09:57 AM
  #29098
SCTDan's Avatar
Originally Posted by Wild Cherry
Hey ? Surprise !!!!
A$$
SCTDan is offline
Old 09-02-2012 | 10:01 AM
  #29099
MantisWorx's Avatar
Originally Posted by SCTDan
A$$
HOLE!!
I also saw on the vid that he wasnt bashing into everyone or hitting lapped traffic What a dick.....
MantisWorx is offline
Old 09-02-2012 | 10:12 AM
  #29100
Matt Trimmings's Avatar
Hey, i have a wonderful idea....if you guys want to talk crap to each other do it through PM's....Lets keep this thread about the SC10 4x4.
Matt Trimmings is offline
