SC10 4x4 Thread
Sounds like using one is a non-starter and it is out of the "toolbox" for me, so to speak.
I've been running the overdrive pulley in the front since day 2 of my truck running, and while it's true that the belt feels "soft" that way, it has never skipped for me until yesterday. I replaced the belt (after 7 months it's just worn out, it was a good bit longer than the replacement) and again, no issues with it coming off.
why so much hate? show the love! i feel like the truck needs a little more rear traction? still kinda wants to kick out but not as bad as before! overall the truck feels more consistent, truck feels more predictable into the turns/ exiting sweepers..
Sc10 4x4 has plenty of rear traction .
Which spring are you using in the rear ?
dup
Not that I can suggest to use a stiffer spring as yellow is plenty....
Borack , if your loose , try blue ...
I went to a lighter spring and lost rear traction......grrrrrrrrrr
when traction goes down i lower my rear ride height... when traction is good i go 24mm f / 24mm r... when it gets looser i dont change anything but ride height, and i drop the rear down to 23.5mm or 23mm depending on how bad it really is. always use yellow springs all around.
when switching to a lighter spring in back to gain more traction ....
Also will find more steering due to the extra chassis roll ...
my truck jumps very flat, which i have most cutouts removed on a flowtek, all but front wheel & side cutouts.
