Like Tree5Likes
SC10 4x4 Thread
Old 07-14-2012 | 11:24 AM
  #26581
ilanstylz's Avatar
Originally Posted by Wildcat1971
Ian,
even a small bit of wear on the pinion or spur can cause massive noise. Try a new pinion and spur and see if it goes away. I assume you have it meshed well. Check your belt tension too. I made mine tight one time and it was pretty noisy.
Before the track that day I put in a brand new pinion and spur since I traded motors......... And I adjusted the mesh several times, even had my friend do it since his sc10 4x4 was freaking quiet compared to mine. I believe it might be what Jake suggested with the idler gear needing replacement. But we'll see what happens after I tear it down completely and redo everything and give it a full car wash so to speak.......
Oh and my rear is set to mid and the front is set to one notch up above the mid to make it a little looser....
ilanstylz is offline
Old 07-14-2012 | 11:26 AM
  #26582
Wildcat1971's Avatar
cool. when I replaced my spur and pinion ir was really quiet for like 1 5 minute race. lol. I think the torque being applied to the spur wears it quickly. Does jc make a silent spur for the sc104x4? in 32 pitch?
Wildcat1971 is offline
Old 07-14-2012 | 12:30 PM
  #26583
Matt Trimmings's Avatar
Unfortunately no they don't.
Matt Trimmings is offline
Old 07-14-2012 | 12:52 PM
  #26584
1M's Avatar
1M
What can be done to reduce roll over? I have 2 sc10 4x4, 1 is older version and can be driven hard into the corners. New Factory Team rolls over easily. Same tires swapping back and forth.
1M is offline
Old 07-14-2012 | 01:04 PM
  #26585
IRM616's Avatar
I heard it yesterday and it sounds like an scte losi. If it runs fast...leave it.
IRM616 is offline
Old 07-14-2012 | 01:09 PM
  #26586
ilanstylz's Avatar
LOL I remember, as soon as you came to the stand you asked me if I was running a losi ........ Yeah but its kind been annoying lately, I miss how quiet it used to be. Oh and I might be in Vegas next week (Fri/Sun) so I might check out the track there, if not I may head back to WCRC I had a blast there......
Old 07-14-2012 | 01:20 PM
  #26587
the 8mm mod bob. pm me on fb if you need details on it.
Geo
twisted is offline
Old 07-14-2012 | 02:05 PM
  #26588
ride height too high?
Old 07-14-2012 | 02:13 PM
  #26589
JEFFs SC10's Avatar
put shims under the ball studs. assuming it has sway bars.
JEFFs SC10 is offline
Old 07-14-2012 | 02:30 PM
  #26590
I too have a very noisy SC10 compared to the others. Keep us posted on what you figure out! I'm new to this 4wd SC thing so your topic is one of my first concerns.
dragginyota is offline
Old 07-14-2012 | 02:44 PM
  #26591
Cain's Avatar
Tech Legend
noticed the noise dropped when I adjusted the belt tension.
Cain is offline
Old 07-14-2012 | 03:30 PM
  #26592
ilanstylz's Avatar
Did you make the belt tighter or looser, and same adjustment on both ends?
Old 07-14-2012 | 03:41 PM
  #26593
SMR 510RR's Avatar
Raising the inside ballstud will make the truck roll more as it lowers roll center.
Compare setups between both trucks and report back what is different.
SMR 510RR is offline
Old 07-14-2012 | 03:45 PM
  #26594
SMR 510RR's Avatar
Originally Posted by zenfilmz.com
Two things i think might help your issues. Torque =wheel spin so im saying u need to go up in rear diff fluid. Add some ball studs up front. 1.1 piston in the rear with a small limiter in side. Maybe go down innspur And like 24000 in the front loosen the slipper a bit too. Weight under the spur and under the servo kinda right side to balance the motor maybe up on pinon a tooth and bump uP oils in da shocks braddah
Basically the exact opposite of that...
Going up in diff fluid will make the two tires more "locked together" so that would only make the truck spin more easily. Raising the front ballstud would lower the front roll center and make the truck softer in the front and would only make the problem worse.
Raise the rear inner ballstud to increase rear traction.
Old 07-14-2012 | 05:26 PM
  #26595
alphaqupsuka's Avatar
Just got back from west coast. Fng awesome, thanks to all who helped me in this thread, truck was great!
alphaqupsuka is offline
