SC10 4x4 Thread
Hey guys. So I decided to sell my SCTE and try out the FT Sc10 4x4. So far i love the truck. I have a few questions though. I am having a hard time get the truck around the track. Always traction rolling. We run on a very high bite track. Will the 8mm mod help me with the traction rolling?
Can you use the plastic c-hub towers (ASC9872) . I don't have my sc104x4 it in front of me to confirm.
Definitely need to parse the 8mm hub mod info more, just not getting the benefit of going high on the hub versus what I am already doing under the inner ball stud.
They have been working out fine for me. I can't swear to the exact height above stock they are, but 3 races on them so far and all is well.
Just curious, but what have you heard bad about them?
With some regrets, I must admit to falling out of love with my SC104x. The divorce just became final and she's moving out tomorrow. I may come back to another one some day, but for now, I will survive. I..will....survive.
Oh, I don't think my other cars or the nitro sedan that just moved in will mind...
The bad.
The bearings are machined too close together so the axle moves back and forth some. Easy fix - a 10mm shim in the bearing hole before the bearing goes in.
The stock black spacers are too big around and hit the hub. You can over tighten the pin and bind the hub in the arm. Easy fix - use smaller diameter spacers.
Other than that I like them. My custom camber location tabs are endless with this set-up.
I'm still keeping mine. I'm actually thinking about getting a 4wd buggy to add to the stable.
5Likes
