Like Tree5Likes
SC10 4x4 Thread
Old 05-20-2012 | 07:47 PM
  #23581
MantisWorx's Avatar
Originally Posted by Oasis
Me?? I have 2 of them..this is some funny stuff here..never said "my" sc10 didn't work..just sayin the 2 stage pistons don't work....but I guess if in your mind they "work better" then so be it....as posted my opinion is just that MY opinion....that's all these threads are..just opinions....and I get "Ramboed" for saying I ran a 13/62 (pretty much the SAME gearing all the pros run)..then I get to hear (read) all the BS about motor temps and bla bla bla..when ya know I'm right on the gearing..ride height..I run 24mm..I got the 27 outta the manual..but I guess I'm the only person who's read the thing....so hate..don't care..
Facts:
you are not right on the gearing
you are not right on ride height
you are not right on the pistons
you obviously only know one pro that runs in his own living room
you ARE making yourself look even worse with every post
The more you type the more i sell!
MantisWorx is offline
Old 05-20-2012 | 07:48 PM
  #23582
fq06's Avatar
Originally Posted by kjohnsiii
Anyone known what might cause the belt to ride on the ridge of the front tensioner?
Just noticed this the other day. Thought that I should shim the bracket out about 2mm to get the belt to ride in the center of the tensioner puly.
No, always lined up, thats odd.
Bearing is good in the tensioner Wheel?
fq06 is offline
Old 05-20-2012 | 07:49 PM
  #23583
ilanstylz's Avatar
Originally Posted by fq06
ilanstylz says nnnnnnooooooooo!!!!!!!!!! black greese on the diff balls, only on the thrust washer.
Clear AE diff lube on the diff balls.
LMFAO!!!!!!!!!! I seriously needed that laugh bro after reading all the bickering on this thread..........But you are completely right, NOOOOOOOO do not use black grease on the diff balls........
ilanstylz is offline
Old 05-20-2012 | 07:51 PM
  #23584
MantisWorx's Avatar
I am taking care of him, it was lithium grease. It is amazing how it really makes a difference!
Old 05-20-2012 | 07:52 PM
  #23585
kjohnsiii's Avatar
I will double check the bearing but I think it's good though.
kjohnsiii is offline
Old 05-20-2012 | 08:12 PM
  #23586
Cameron Kellogg's Avatar
Originally Posted by Evil Genius jr.
Question about V2 tuning. I am on a loosed outdoor track and am currently running 6 pins. The truck breaks loose way too easily (go down on pins) but lacks acceleration (Go up). What should I do?
low bite track = less pins
high bite track = more pins
If you come out or go around high speed corners and the rear comes around try taking out some pins. Always tune for the majority of the track. The center diff will make the truck easier to drive but will not fix a set-up that is off or the wrong tires for the track.
Cameron Kellogg is offline
Old 05-20-2012 | 08:17 PM
  #23587
IRM616's Avatar
Originally Posted by sbrewer
Yes I did, but didnt use much. jusr black grease on the diff balls
I had the same prob, I got excited to install all my goodies and messed up the grease.I'm sure Marcus will review the setup with you. If you have any other question I'll do my best. Good luck.
IRM616 is offline
Old 05-20-2012 | 08:48 PM
  #23588
Oasis's Avatar
Originally Posted by MantisWorx
Facts:
funny..so 24mm ride height is "not right" (i run Kody's indoor set-up)
So Mayfield & Cavalier are both wrong on the gearing 13/62 for a 550 4.5
once again its your opinion on the pistons..
The gearing & ride height are taken off the set up sheets, so i have no idea where in the F you came up with "you obviously only know one pro that runs in his own living room"..
once again i am providing proof of what im saying and your talking sh*t so whatever marcus....
Oasis is offline
Old 05-20-2012 | 08:51 PM
  #23589
Oasis, what crawled up your azz and died? I have been racing r/c for over 20 years. I've seen the good and bad. The 2 stage pistons DO work. They just don't work for everybody in every situation. Nothing does. They do exactly as advertised. The center diff does EXACTLY as advertised. If it weren't for those two upgrades, I would have dumped this poorly-engineered pile a long time ago. I ran right with a well- driven Losi I today on a blown out track. The only limitations I have are age, and worsening eyesight. The truck is pretty good now, but I am looking forward to the Mugen.
rcmiket is offline
Old 05-20-2012 | 09:07 PM
  #23590
IRM616's Avatar
This is a silly question oasis...is ur default a current picture of you?
IRM616 is offline
Old 05-20-2012 | 09:10 PM
  #23591
Oasis's Avatar
good for you..on the 20 years..and just an FYI..I've NEVER said anything about the center diff..if fact I'm actually SORRY i bought one seeing just how big of a ..
I will form my opinion on it when i use it..I have asked about the best area to use it..but have never had marcus answer..
i had "questions" on the pistons..being the correct size, emailed marcus about it and have been given BS over it it ever since..poor service..so this is the last time i will ever buy his products..
Oasis is offline
Old 05-20-2012 | 09:14 PM
  #23592
Oasis's Avatar
yeah..a puddy kat..yep this is a silly question but i would expect no less from you..
Oasis is offline
Old 05-20-2012 | 09:19 PM
  #23593
Oasis's Avatar
Angry
sooooo many fanboys..
so what have i said thats wrong..the 24mm ride height? the 13/62 gearing that most of the team drivers have on their set up sheets?
my opinion that the 2 stage pistons that I HAD didnt work? maybe yours work but mine didnt work..
Oasis is offline
Old 05-20-2012 | 09:39 PM
  #23594
i ran my truck for the 1st time today wit hthe 8mm rear hub mod. A+ ! thanks to the guys here and their info
twisted is offline
Old 05-20-2012 | 09:40 PM
  #23595
IRM616's Avatar
Meow MEOW
IRM616 is offline
