Like Tree5Likes
SC10 4x4 Thread
Old 05-15-2012 | 07:20 AM
  #23206
Originally Posted by hpiaddict
I have just bought the FT kit and and going to have to use a 540 setup until I can get an RX8 to install. In the mean time I will be running a Ballistic 6.5 and an LRP SPX Stock Spec. This does not have a heat sink. Would this truck and motor create too much heat on the speedo?
It doesn't look to be as overbuilt as the RX8.
I'd try contacting the manufacturer, or at least be monitor temps closely and adjust gearing to stay safe.
It's rated at 400amps, but with a 3.5turn motor limit...
I can't think whether the limit is to not go higher or lower than 3.5, but I think you are supposed to not go higher.
You are proposing a Ballistic 6.5, I think there may be a problem.
http://www.lrp.cc/fileadmin/lrp_anle...tockspec-e.pdf
KewlToy is offline
Old 05-15-2012 | 08:31 AM
  #23207
Oasis's Avatar
Nope..your not suppose to go lower than a 3.5..a 6.5 is ok as far as limit goes..
Oasis is offline
Old 05-15-2012 | 08:33 AM
  #23208
Yeah, the bigger worry might be the esc's inability to dissipate heat though. The TC Spec version is recommended for 4x4 trucks.
Krio is offline
Old 05-15-2012 | 09:39 AM
  #23209
Yeah I have been very curious about how the temps would be. I have ran an 6.5 in my b4 without an issue but I was worried about the additional weight. Any suggestions on a cheap speedo that would run the ballistic 550 motors?
hpiaddict is offline
Old 05-15-2012 | 10:37 AM
  #23210
drolmaeye's Avatar
I'm pretty sure you could use a Speed Passion GT2.0 going for $90 right now. Double-check, though by PMing someone who runs them (you can see a bunch in the sigs in this thread, I think) or by checking info in the Speed Passion thread. Of course, Novak's Havoc Pro SC w/ X-drive at $140 can run them.
drolmaeye is offline
Old 05-15-2012 | 11:08 AM
  #23211
cyljock's Avatar
I've used a 5.5t ballistic 540 motor paired with a kinetic in the past which is basically the same as a havoc pro sc. I ended up using the stock 48 pitch spur and a 13t pinion. The havoc pro SC with fan installed will fit under belt. Definitely a solid setup to consider.
cyljock is offline
Old 05-15-2012 | 11:34 AM
  #23212
I used to have a gtb... Burnt it up I think running the 550. I thought that it could run it but it couldn't I guess. It said any Novak motor but I guess it was only 540's.
Old 05-15-2012 | 11:51 AM
  #23213
BlueGlowBoy's Avatar
Note, the SXX TC Spec WITH a fan is what AE has many team drivers running in their 4x4...
Honestly, I think the SPX would do it if you put a good fan on it.
HK's 150A 8th scale speedo or their 120A "car" speedo are pretty darn cheap....it would get you through until you can get an RX8.
BlueGlowBoy is offline
Old 05-15-2012 | 12:21 PM
  #23214
murky123's Avatar
what is the benefit of the 19T front pully over the stock 20T pully ?
in what situations do you prefer the 19T over the 20T ?
murky123 is offline
Old 05-15-2012 | 12:22 PM
  #23215
ilanstylz's Avatar
If money is an issue for now, brushless hobbies sell's a sensored 120a esc for $58 bucks and comes with a usb adaptor to change settings on your pc/laptop....... Very good esc for the price and great customer service.....
ilanstylz is offline
Old 05-15-2012 | 12:27 PM
  #23216
Originally Posted by Wild Cherry
Improvements ?
These are why my the lap times have improved..
VTS Slipper
Ae chassis brace ( stiffer than my homemade brace)
8mm rear hub mod
Team steering rack ( really improves the feel & steering response)
JConcepts pressure points tires
Kody's latest JConcept set-up
RPM arms
JConcept High Flow body
Reedy 4.5 550
Team Li-po tray ( stiffer chassis)
the 8mm rear hub mod, i dont know the ins and outs of this but is it to lower the roll center ?
ive raised my inner ball studs by 3mm and that helped. im curious about this mod and what it does. time to search.
twisted is offline
Old 05-15-2012 | 12:42 PM
  #23217
kjohnsiii's Avatar
Are u running one in your 4x4 if so what motor?
kjohnsiii is offline
Old 05-15-2012 | 12:48 PM
  #23218
ilanstylz's Avatar
No I'm not, but I believe there are a few on here that are just forgot who lol.........My cousin has the 80a version on his 2wd sc10 with a 13.5 trinity motor boosted and he hasn't had any issue's and temps are always low.......
Old 05-15-2012 | 01:59 PM
  #23219
Wild Cherry's Avatar
Tech Legend
I'm like you , just learning to understand the technical ....
Believe it raises the roll center not lower .
8mm mod is
better for bumps , better initial grip, less roll and likes the Sc10 rear yellow spring ....
Wild Cherry is offline
Old 05-15-2012 | 02:31 PM
  #23220
... 8mm mod is
"The 8mm mod" is..?
different ball-studs?
both front and back?
Purchased anywhere?
KewlToy is offline
