Like Tree5Likes
SC10 4x4 Thread
Old 05-09-2012 | 10:30 AM
  #22936
Originally Posted by ilanstylz
I don't think you can buy the spring separately..........At least I haven't been able to find anywhere you can..
It's the same spring as the V2 one they offer for the B4, T4, SC10.
http://kriostasis.com/store/index.ph...products_id=22
Krio is offline
Old 05-09-2012 | 10:32 AM
  #22937
ilanstylz's Avatar
cool thanks............
ilanstylz is offline
Old 05-09-2012 | 10:41 AM
  #22938
Originally Posted by twisted
ive asked this before but it never got an answer,maybe thats because "no" is the answer...
anyway, anyone running the stock rtr esc and motor ?
iam and the reedy 550 3500 kv motor gets hot, about 170 after 8 minutes and its not as fast as the other motors the guys are using in 4x4 open.(ae says the max temp is 170)
the esc so far has been good but i just read on another furom that if you use a different motor other then the rtr reedy motor "bad" things happen. as for what those bad things are i have no idea.
i was thinking of geting another motor like a 1410 and running it with the stock esc. no im unsure what to do and money is getting tight.
Twisted,
I have the rtr version and it also ran very hot. I fixed the problem by going to the mantis center diff. i also decided to replace the motor and I'm currently running the castle 1410 with the stock esc and a savox servo without any issues. I have a MMP to put in but will use the stock one until it dies.
jodyfj40 is offline
Old 05-09-2012 | 10:42 AM
  #22939
Thanks Krio
jodyfj40 is offline
Old 05-09-2012 | 11:05 AM
  #22940
Originally Posted by jodyfj40
Twisted,
was the slipper contributing the hot motor ? is the mantis center diff the same as the rcshox unit ?
and one more question, how is the 1410 compared to the stock motor ?
thanks !
twisted is offline
Old 05-09-2012 | 11:14 AM
  #22941
Originally Posted by ritojr
I cant comment on what happens when you put another motor on the stock esc, but I just recently got my truck and for now am running the stock reedy motor and esc. At my track, it is more than enough power. I ran it for the first time last week and can honestly say I was not getting out powered by anyone. I was getting beat because of my handling and skill getting used to the truck. My track is indoor, small to medium size so power isnt a huge necessity. If you are running on a huge outdoor track I can see where it may be a problem. But for what I am using it for the stock esc and motor are fine. Hope this helps
yea on an indoor my truck is fine speed wise. no problem till i get outside on the big tracks. whats hte temps on your motor ?
twisted is offline
Old 05-09-2012 | 11:37 AM
  #22942
BlueGlowBoy's Avatar
Twisted,
That kind of gives me the impression that the excessive heat is not being generated by the motor, but more that it is heat being transferred to the motor plate by the wimpy slipper that is included in the RTR..... I remember that was a fairly common issue before the HD pads, Garodiscs, clutch basket, etc....
BlueGlowBoy is offline
Old 05-09-2012 | 11:39 AM
  #22943
I never got above 160 the other day, but those were only 5 min main. I took it out for some extended practices as well and still didnt see anything really over 160, but I cant tell you how many minutes those sessions were. ill check what pinion I'm running to see if that is helping keep me a little lower
ritojr is offline
Old 05-09-2012 | 01:21 PM
  #22944
IRM616's Avatar
http://youtu.be/t1FMXYtXV_4
or
http://www.youtube.com/watch?v=t1FMX...feature=g-vrec
start at 5:00 mins into it, also is this the same for SC104x4?
IRM616 is offline
Old 05-09-2012 | 01:38 PM
  #22945
CEW
I think you are running a 14 tooth pinion and I ran that truck for 20 minutes straight and was still in the 160's. I never saw it hit 170 as Twisted is seeing.
CEW is offline
Old 05-09-2012 | 01:40 PM
  #22946
CoyoteSlash's Avatar
Originally Posted by jamr1130
I only run on indoor high bite clay tracks so my experience is limited to that. But I will say that these setup changes have changed the truck's on track attitude in the positive direction. I think now the only limitation to the truck is my driving ability. Well, YMMV.
Indoors I love the truck. I set this thing up as it sits, and roar. 4 months ago, I could keep up with Cameron for a lap till I messed up. (I'm not very consistent as his speed) I have no indoor complaints, any problems are 100% my problems. Outdoors, I can tune my slash to beat losis, My "race" truck chassis however...
Originally Posted by MantisWorx
Food for thought Sean and it some things to think about:
Tires, i have noticed that with my SS blockades although they have great grip but ballon to about 10" in diameter! well if you think about it when you go into a turn they get smaller again and that makes weight transfer do all kinda crazy stuff, seeing that the truck is light i think it is more obvious. this weekend i am going to buy a set of Losi tires (they are cheap and work well here) and strap them to see if it helps. i do notice that the truck is more planted with other tires but the blockades are the worst!
You have an extra set of V2 pistons, take the rear rebound set drill them to 1.3 and go up to 32.5 in the rear, keep the shocks mounted on the inside arm hole.
I will try that. Only thing is my truck felt great with the new Blockades. The thing has so much bite and drove aggressive and kicked some ass until the track blew out and now it's hell. I was swearing by the blockades till that point.
Originally Posted by SCTDan
I did exactly what Marcus said with the pistons front and rear with 35wt in front and 32.5wt in the rear. I also added that steel skid plate on the front adding about 5oz low,front, and center. My weight bias is 48% front to 52%rear and it feels well balanced on the track. This last Sunday I had several guys wondering how I set up my truck to keep it so smooth and planted. It weighs in at a hefty 6.9lbs but still drives inside of the Losi's. For outdoors I need the weight. The only area of our track that gave me issues was a 180deg turn at the end of a straight that is down hill and off camber. My tires had good side bite and too much speed would cause a wicked traction roll.
Weight's definitely my #1 right now. I think i'm putting a sheet of lead on my chassis here soon to try. I have many chassis's from Centermount battery to some of the chassis brace prototype stuff I was doing. So I have some test ability. If it comes down to it, I can consider the Exotek and a bit more weight, We shall see.
Thanks guys. I'm no where near given up, Just back to a little frustrated.
CoyoteSlash is offline
Old 05-09-2012 | 02:26 PM
  #22947
jpure009's Avatar
Questions?? Shipping Fee
Thank you for the props! I just received another truck to part out, so stock should be updated by the end of today.
Is there a shipping charge??,
Couldn't tell unless I went past checkout.
I am by NYC
THX
jpure009 is offline
Old 05-09-2012 | 02:43 PM
  #22948
I am by NYC
THX
Sorry, I need to mention somewhere on the site that it's a flat $4.99.
Krio is offline
Old 05-09-2012 | 03:41 PM
  #22949
Evil Genius jr.'s Avatar
I've been reading through tons of guides and threads but can't seem to find an answer. What does changing the F/R diff oil do? 30K vs 3K up front changes what?
Thanks!
Evil Genius jr. is offline
Old 05-09-2012 | 04:04 PM
  #22950
I've purchased the rtr version of this truck, I have to sayi was bitterly disappointed in it. The truck was near un drivable track happy as hell very nervous at speed.
I've also got the losi scte rtr now or of the box with the tyres it came with I was driving like a pro!
I haven't given up on the sc10 yet and had got the upgrade pack from AE im yet to run it.
Reading through this thread im mightily confused as to which direction I should go to get the truck confident on the dirt tracks
To say im mightily disappointed is an understatement considering how awesome the losi is out of the box
muzzytt is offline
