SC10 4x4 Thread
Guys, did a deal for a Tekin RX8 and it came with one of these motors:
Tekin Redline SC4X Sensored Brushless 550 Motor (4.5T)
I'm currently running the Castle Creations 1410-1Y 4-Pole Brushless Motor (3800kV) and am very happy with it, I bought the RX8 for my Losi 8.
I need to get some pinons for the 5mm shaft of the tekin so waiting for those before I can try it. I have a Hobbyking 120amp ESC in the SC10 and love it, it should run the Tekin motor no problem I hope.
I'd like to hear from anyone who has run both motors so I know what to expect from the Tekin, I like that it will be sensored but is it really any better than the CC?
Ae v2 slipper is dialed I have to admit , could still do the same with the old one though. But with less power maybe than My new Reedy.
My original brace was good enuff also & still have 1st brace on for good luck, just in case ....
Get those RPM arms on pronto !
I don't think I have ever been behind , rather setting the pace ....
KJohn , A real good time , really enjoyed racing the Sc4x4 last night with you .
They are about twice as stiff as the Ae arm though and as a result the truck is a lot more consistent ...
You put the Ae rear camber mod on yet ?
I ran my FT kit yesterday and it is a pretty nice truck. Coming from Losi I expected it to have more steering, but WOW. I had to back my d/r off to 80%. Ride hight is key to this truck. I set it at bones level and it was too high. I found that just below suited the track best for me. I am curious to put it outdoors here soon... so far so good. I may actually have to try to take steering our of the truck as to tighten up the rear a bit. ( this is on a clay track, outdoors will be different i am sure.)
Esc choice
Hey I am making the switch to a pro4 4600 and wanted your guy opinions on either a hobbywing or rx8 for esc and what the pros and cons are. Also will there be a power difference.
Pros for HW:
Cheaper esc
Cheaper programming card
Cons:
No warranty
No customer service
Pros for RX8:
Outstanding customer service
Great warranty
Prob. one of the most popular esc's out there today
Cons:
Little bit more expensive as well as for the programming card.....
So IMO I'd def. go with the RX8, they offer a 6 month warranty and even if its out of warranty and something happens to it tekin will fix it for a cheaper fee then buying a new one.......
Can't say which one will give you more power since I've never owned the HW one, but with my RX8 pro4 4600kv motor I have all the power I'll ever need and that's even with the settings very low (timing, etc).......
Thanks for your quick response. I will look at the rx8 while I wait for some other opinions. Another question I currently am having a real bad push off power. My basic setup is 2 stage pistons 25/25 wt. v1 center diff yellow front with blue fronts on the rear, exotec chassis. Front links on inner tower with 2mm washer. Rear is outer on tower inner on hub with like 5 or 6 mm washers under ball studs. Any suggestions?
RX8 IMO
Pros for HW:
Cheaper esc
Cons:
No warranty
No customer service
Pros for RX8:
Great warranty
Cons:
Pros for HW:
Cheaper esc
Cons:
No warranty
No customer service
Pros for RX8:
Great warranty
Cons:
What diff oil?
Try 7/5 or 10/5
Try 7/5 or 10/5
No your fine,
Is your travel set right?
I mean the steering travel.
Sc10 4x4s rock
I've always Been an ae guy at heart went with losi then heard the ft sc10 4x4 was out sold the losi and wow I love this truck ran it on a out door track with rx8 and 4600kv ima mess with it some but was very impressed I ended up finishing second won the first two qualifiers I'll get some more practice in gotten a lot of info from this site love it!!!!!!!
