Like Tree5Likes
SC10 4x4 Thread
Old 04-10-2012 | 10:07 AM
  #21166
CraigMBA's Avatar
Originally Posted by sand geek
I could clear them if I hit everything perfect. Im going to pick up the clutch basket and garodisc. I did not know there was a ft upgrade kit. I will look into it as well...Bling always makes things faster
It's like 45-70 bucks, and you get the multi part slipper.
http://teamassociated.com/parts/details/91174/
CraigMBA is offline
Old 04-10-2012 | 10:09 AM
  #21167
Originally Posted by Cain
Maybe I am missing something but isn't the SC4X also a 550 motor like your Novak 550?
I think the rotor on Tekin is 12.5mm and the rotor on the stock Ballistic 550 is 12.3mm?
May see more torque with the Tekin. Could be more heat resistant too since its thicker, though on these SC104x4s may be a non-issue.
I liked mine but the 540 4 pole Tekin is definitely more powerful.
You're correct, it is a 550 can as well. I mixed that up. So, it's very similiar to my current motor with maybe a little more top end due to it being a 5.5t vs a 4.5t.
I'm not really in the market for a new motor, just got offered this as a trade for a charger that I'm no longer using and am trying to decide if I'll ever use it.
Snafujg is offline
Old 04-10-2012 | 11:26 AM
  #21168
kjohnsiii's Avatar
Originally Posted by Wild Cherry
Don't believe you need to replace the arms , suggest instead to get the coated suspension pins if you don't have yet ....
If you have major slop on the ft arms maybe replace , but I ran the arms for almost a year before I replaced with brand new again..
Thanks cherry, I believe the ft has the ti coated hinge pins. I think that the arms have prematurely slipped because of the extra weight from the exo chassis?
kjohnsiii is offline
Old 04-10-2012 | 11:46 AM
  #21169
CraigMBA's Avatar
I sort of disagree with Cherry. If you race indoor, they will last forever because the speeds are lower, but if you race outdoor, not so much.
The first FT parts I put into my truck were the TN hinge pins, and I can still warp a set of A arms to where they are unusable in two race days outdoor if I don't rotate them L/R every race day. I marked one side with a silver sharpie and I'm up to eight race days on them now, but they are probablly near the end of their life.
I never ran a set long enough to get slop on them.
CraigMBA is offline
Old 04-10-2012 | 11:57 AM
  #21170
kjohnsiii's Avatar
Smile
Thanks,
Anyone ran the rpm arms ?
Looking for some input on the quality.
I hate slop on my trucks. Some just let it go, I always have to address it...
Old 04-10-2012 | 12:01 PM
  #21171
Cain's Avatar
Tech Legend
Thanks,
The RPM a-arms are actually pretty good. I was very surprised with how stiff they are compared to other RPM stuff I have used in the past.
If I recall correctly, I think people were actually going to the RPM a-arms at one point as they didn't warp as easy as the stock AE arms.
Cain is offline
  #21172
Wild Cherry's Avatar
Tech Legend
Kjohn
Your ride is almost brand new , truck does break in a little though and maybe now you notice a bit more play ?
That extra weight from your Exotech is only a small amount and really won't make much difference with wear & tear ...
hope to see you @ track soon , still have your note book I believe...
Wild Cherry is offline
Old 04-10-2012 | 12:05 PM
  #21173
Tech Legend
His truck is almost brand new , still have not seen one wrap arm yet BTW....
Outdoors ?
Thatmakes a difference , O really ...
Old 04-10-2012 | 12:11 PM
  #21174
kjohnsiii's Avatar
Outdoors ?
Indoors. Clay small jumps.
Old 04-10-2012 | 12:14 PM
  #21175
Outdoors ?
I have a warped arm I can send you
Sofa King is offline
Old 04-10-2012 | 12:19 PM
  #21176
Tech Legend
sofa
I have some of my old arms in a bag when ever U need ...
Old 04-10-2012 | 02:48 PM
  #21177
JEFFs SC10's Avatar
Mantis replaced all 4 of mine LOL. I run outdoors.
Even Jarosz admitted to arms warping..
JEFFs SC10 is offline
Old 04-10-2012 | 02:49 PM
  #21178
fq06's Avatar
What he said, the RPM arms are much better than stock.
A better fit and the shock pin retaining screw does not just spin... It grabs and bottoms out.
fq06 is offline
Old 04-10-2012 | 03:04 PM
  #21179
CraigMBA's Avatar
Thanks,
I bought a set. They are stiffer than the AE plastic, and warp worse (more quickly). It is my opinion that the plastic doesn't actually warp, it fractures along the weakest part, which makes them look like they are warped.
I had a set that were really bad (instead of being in line, the inner hinge pin holes lined up a full pin width away from each other) but I tossed them. I sent the rest of my collection to Chris at AE because he wanted to look at them. I think it was 12 sets deep. Some of them were warped so bad I had to pound out the hinge pins with a small ball peen hammer and a punch. When I rolled them on glass, all the hinge pins remained straight. I always check them after every race day (they are already out when I flip the arms).
If you're racing indoor, IMO it's not such a problem because the tracks are smaller and tighter and when you hit something, it's at much lower speed.
You're wasting your time. WC has never seen it because it obviously doesn't exist. This is why I have him on ignore.
Never let the facts get in the way of a good story.
CraigMBA is offline
Old 04-10-2012 | 03:11 PM
  #21180
MantisWorx's Avatar
I love "ignore" LOL
MantisWorx is offline
