Hong nor new 1/10 buggy?
#31
Good so it'll fit the class but now there's a matter of keeping the hard wing from the crt.5 and finding a body that will fit and mount properly. My E conversion is the rc bros version so the battery stands up. That may be a problem. A 3-diff 10th scale 4wd buggy will be crazy tunable! I'll have to check with dirtburners or nankin to do a test fit of their different 4wheel buggy bodies. I'm thinking it'll be dremel it up and go.
FYI the rear is too wide to be ROAR legal by 1/2" (needs to be 250mm) the B44 bodies fit perfect with a small amount of cutting in the front.
#32
The CRT.5 is specified as 279mm wide which is an inch too wide but that is with truggy wheels. I measured my JAmmin SCRT10 and the axle studs are 250mm tip-to-tip so a zero offset 4wd buggy wheel would be ROAR legal. I will re-check this but I am pretty certain.
#33
Thank you Mantisworx. I'll get a body and run a test fit friday. I'm now left with figuring out a way to lay the battery down so it fits the low pro body style. But then I'm worried about the battery width interfering. Hmmm I wonder if it'd be safe enough to get some industrial hook and loop tape in lieu of a battery box with straps...
#34
i have a customers car sitting and front of me and with buggy wheels it is too wide by 1/2" no doubt about it. but that is with LOSI,AE and CAster wheels. i am having some negative offset wheels machined right now but i dont think you can buy any on the market at least none that i know of. if you know of some that you can buy point that link in my direction, the customs ones are not cheap!!
#35
Much better weight distribution with saddlepacks, only had to twist two collars about 1 turn to balance the car with no additional weight. i just want to say that the conversion ROCKS in buggy form! within 10 laps "off of the trailer" i was able to beat my personal best time and the track record, and we have some factory sponsered drivers locally and get two to three heats of 4w mod. i originally took on this project because that is what i do but i am definately about to make another for me and use as my interim car til my new one comes in.
#36
Wow! That thing looks great. I dont have saddle packs but probably 10-2s lipos of varying MAH and C rating. I love the customer saddlepack look of this conversion though. Do you think the right side would fit a battery tray? The balance may be off but I could also mount the esc to the servo side to offset the motor. I'm probably going with a Sidewinder SCT or my Medusa 3300. Also what did you use to change the body mount?
#37
#38
love it glad i waited to buy a 4wd
#39
* deleted *
#41
not sure if a battery tray will fit or not, its a tight fit, you can get saddle packs for 30bux from gen ace, and you really only need one pack maybe two, the performance advantage is just better. i velcro'd the rear and used a std body post to hold the front down. im using a center dif and there is no way im going back to a slipper, the tuneablilty is great, it will handle as much power as you can throw at it, in fact it feels better with a 4.5 than an 8.5 even though its ballistic!
#44
Other than the wings, shock towers, buggy shell, 1/10 wheels not sure whether there are other things missing for the conversion if i were to get these instead?
Ofna OFN40925 Conversion Kit to Long CRT .5
#45
And for the long chassis conversion you'll probably need different length center shafts as well.
Not sure, but those are my thoughts...
