Some good racing for sure...Jeff,Doug and Josh just killing it out there..Low to mid 25's for lap times....Pretty sure that was the last time I'm gonna race my slash.
Getting into the truck tonight adding chrispin's and washers, center diff drive's. The Losi looked good right outa the box when Jeff was driving it..... killing it. I'm just woundering what kinda worms I might be opening going to Diff fluid's.
How you setting you'r diff's up?
yea it was a blast,he made it interesting for sure. i set my diffs 3-3-2 , it handles awesome. idk what people are talking about with wear my tires after 5-6 nights of racing my grid irons still look decent, i plan on using them still, i did move my battery foward but everything else it stock as far as set up goes. one thing you wanna do it check your servo saver. Last night i noticed mine was loose, put loctite on it and have 2 threads showing now, i had so much more steering, this is wat caused some issues in the main because i had to get used to more steering
so i completed my ten-t to SCTE conversion. only lightening that was done was titanium hinge pins and HD outdrives in the center. ready to race, it was 6 pounds, 5 ounces. seems light. what do they typically weigh right out of the box?
electronics: tenshock 3663 motor, hobbywing SC8 esc (feels like a tank), savox 1258, gens ace 5000mah 40C 2 cell.
6lb 5oz is about normal. 550 motors it will be around 6lb 7oz. Not a TON of effort but some key parts and a little shaving getting close to 6lb is not super hard.
i just picked up my new scte ,and the first thing i looked at was the battery tray and thought ill cut the esc tray off first and go from there.i cut the esc tray off my buggy and used 3 or 4 layers of servo tape and my rx8 has been fine.
I was wondering how you guys have your battery wired?
I plan on running these packs and it says it comes with a bullet connector? Would I just need to connect these to my 12 Gauge wire and the solder on to the ESC?
Also for the charging, are you guys using a banana plug to female deans connector? I currently using a banana to male deans to charge my 4s packs for my 1/8 buggy so I figured I can just use a banana plug to female deans adapter to charge my 2S packs.
http://www.amainhobbies.com/product_...-ROAR-Approved
ten-t bumper pics
Could somebody with T-bone ten-t bumpers post some front and rear pics of it with the body on? Also Could you measure the width of the front bumper?
How did the pins, shims and blocks look in your diffs?
The rear diff went bad on my truck today. I have been running the Chrispins from day one. The spider gears lost their teeth. I did the OFNA mod at the track and had it back together in time for the main. It was areally good turn out today, there were 19 4x4 SCT in attendance. I qualed 5th and finished 5th.
http://www.amainhobbies.com/product_...ng-Gel-1-Sheet
I raced with badassrevo yesterday and my rear diff went out in the main. My diffs are stock except for your pins. Spider gears and the shim behind the sun gears showed wear. Chris pins, stock blocks, and the small shims still looked new. I will be doing the ofna mod next.
