lighter is for everyone.. you do need to make sure you change your setup accordingly.. you will not push, you will not have jumping issues other than your own. Keep in mind this vehicle is not a truggy with huge wheels and it is not as 'over powered' as a 1/8 buggy so you don't have as much ability to self correct. You do need to hit jumps with more thought than your avg 1/8 setup, think of it more like a 1/10 (ohh wait it is a 1/10 ;P)
This is my basic setup for anyone who hasn't given this a shot yet I highly recommend Casey's basic setup with these changes
FRONT - 37.5wt, stock springs, stock discs, NO SWAY, droop 89, and ride hight at 27mm.
REAR - 27.5wt, silver springs, stock discs, 1.8mm sway, droop 101mm and ride height at 28-29mm.
-AKA enduro 'soft' for pretty much any condition outdoor
-SC10 stock tires for our indoor offroad work best ***I do reduce droop a lot on our indoor offroad track
Found it.
He's simply not racing like we are or on his lid a lot if he's getting 18minutes out of any setup with 6500 or less mAH. The 2pole 550's are not as effecient as the 4-pole castle motor, so on the same track with the same setup the same battery pushing the same lap times the castle system is going to run cooler and longer than any of the current 2 pole motors that we run in these trucks. Even with a dual stage esc like the rx8 that runs sensorless at higher RPM's, the only way you could get the effeciency he is claiming at least out racing is by gearing low, or taking out a ton of torque out in the esc, thus making it even less comparable to the 1410. The book maybe re-written soon though with the launch of the newer tekin 4pole motors.. I'm pretty excited for these bad boys.
one time i got like 14 minutes out of my 2200kv 5k 4s lipo but i was babying it
in my truggy. so like you stated it could be he wasnt putting it to the limits. do you run the lvc lower than 3.2?
eight-t thats one hell of a track lol. i didnt want to quote you as it might make the next page all big due to the photos
SHeesh, thats lots of track ! 2 of our club race tracks would easily fit on that monster.
pardon my ignorance but where is crc ? That looks insanely fun !
That setup should be a good starting point , thanks...
I wish that track was here in So Cal, that would be awesome!
on that track, 8ight-e and the other top drivers run 16 - 17 laps in 10 minute main, averaging 33-34 second laps. unlike me, running 40 second laps and getting 12 laps
i'll get there though. running with guys much faster than you are makes you better.
