#9001
had some crazy fun at my local track this past saturday.
was running my bone stock losi against a couple of 1/8 nitro buggies.
the track is more on the 1/8 scale size (huge triples) but i managed to get a best lap only .5 seconds slower than the buggies fastest lap. this is with almost bald stock tires too.
i've said it before and i dont think i'll get sick of sayin it...
I LOVE THIS TRUCK!!!!
oh and i got my temp issues figured out, after 8-9 mins motor temp is @ 140-145 with a 19t pinion.
MMP/1415 combo.
MMP/1415 combo.
#9002
#9003
I have ones from the last two rounds, I just dont know how to make them small enough to post them here.
#9004
MMP/1415 combo.
MMP/1415 combo.
What gearing were you running again when you had high temps?
#9006
It got to about 165 with either. The problem was yhe default settings on the mmp, had to bring timing to the lowest setting, and brought punch control up to medium.
Still having a problem with lvc kicking in with the pack at 7v
#9007
#9009
SCTE
OK, so here is the setup we ran this weekend. Thanks to Casper for shrinking it for me and to Aaron for his help getting it dialed in.
The closest stock springs to what we ran would be gold up front and black in the rear.
#9010
This happens quite often, even with my punch control set on high. Ive tried the auto and 6v lvc settings and it doesnt make a difference.
#9011
hopfully I won't be a problem, has anyone been having problems with this on the rx8?
#9012
It says on the sheet (new Spring) are they more springs coming out? Just curious but thanks for the set
#9013
Thanks again and see you at Rnd 4.
#9014
I've always had that problem with the mmp even in the 2wd sc trucks I just turn off the lipo cut off and pay real close attention to what your putting back into your pack after every run. work your way a little at a time to you know you can't go any longer. I hope I don't get this problem with the RX8 as I don't beline I can turn the cutoff off, anybody know of a way to get it off, I seem to not be able to find a way to turn it off?
