#8686
Racetek (Out Front Frames) carbon hingepin holders use the losi inserts so they ARE adjustable, and also allow you to ditch the plastic covers. What sense is there in 70$ hingepin holders if you can't show them off?
#8687
well i have good tools and wondered what the problem was until the 2nd time I did the diffs and managed to strip 2 of 12 screws holding the diffs together.
Those screws are pretty crappy quality not to mention all or any of the chrome or shiny buttons they might as well be made of Lead they are so soft...
so yes indeed i will be lined up for a screw kit dont care if its Ti or steel but they deffy gotta be better than the stockers.
I dont think you should have to be "careful" every time you undo or tighten every screw on this thing.
sure some of the delicate ones, but they ALL seem in danger of stripping every time you put the wrench to them.
The fascination with "button" head screws is mostly part of it too they use smaller hexes than a similar sized socket head screw..
#8688
I'm testing these parts right now. Adjusting anti-squat and kick up can be done by having different hinge pin holders with holes in the correct place. After talking to Steve, we didn't like the idea of making them to fit the inserts since the plastics inserts tend to wear out and ovalize.
#8689
So I'm putting the motor In my scte for the first time and my motor mount will only let me run one motor screw... is this normal?
#8692
I guess I am not understanding...are you referring to the pin captured by the plastic retainer? Come find me at JBRL and I can get you taken care of one way or another, lol.
#8693
#8694
I don't mean to offend you but your normal shop tools don't hold a candle to hobby grade allen wrenches. Even snap-on hex wrenches are junk compared to the ground tips, MIP, Losi, AE, Hudy, EDS use. With small hexes the tool tip means EVERYTHING!
I have not stripped a screw yet on the 8ight or Ten-SCTE and I use a power driver most of the time. I invested in MIP speed tips though which are as good as they get. Just saying with good tools you should not strip anything.
I've ben using Integy tips in my drivers and cordless drills for years and still holding up great.
#8695
I haven't stripped a screw in my xxx-sct either....not the point.
The fact is the screws in the Ten are crap...soft, and not anywhere near hard enough.
#8696
#8697
so i have a brand new in box scx4 4.5 turn and rx8....do i return the sc4x and get a 1410 or just try it? been hearing alot of heat issues with the 4.5....but you always hear the bad...
#8698
I run the Tekin rx8 with a 4.5, geared 15 on a outside track with 30 to 33 secound laps and have no heat issuses .Go on the tekin set ups and set it up the way they say and you shouldnt have a problem.
#8699
They have to cut corners somewhere to make it more afforadable to the masses. IMO the hardware is a tick soft but with due care they are more than fine. I guess the kid who works for a bowl of rice day was not on his game when he built yours?
#8700
I will be getting all of my Viper gear soon enough though so I will flyin!
