#6934
#6935
Im not trying to be nagative. But if the tracks are that wet up here races cancel. I wouldnt even run in that muck. Hope your electronics and motor are still ok.
#6938
I have a brand new Xcelorin esc....could I use that instead?
Can all esc's run these motors or is there specs that prevent it? Piises me off, I asked and was told these esc's and motor would work perfectly. I just wasted money that didn't need to.
Are the castle motors 2400kv difficult to turn by hand when pinion is on and your just rotaing shaft? Or should they spin freely?
#6939
Dumb question....is it normal to have to switch the motor direction in castlelink to get it to go forward when pressing forward on throttle?
I couldn't figure out what was going on...normal is stock setting.
AnyUser....can you tell me what setting you use with your combo? I bought this based on your recs. I have no idea what all that stuff means in racing terms. I want a good race setup.
#6941
When I got my Losi I took the m11x rec out to go in my new truck from my Slash 4x4,in that truck I have the castle 2400 sct set up with a Hitec 7955ti gear servo and it had no problems.When I put my Spectrum dx3e radio and rec in it it would glitch terrible, cant run it at all!And of coarse running RX8 in the Losi!!! So your radio gear will also affect it performance as well!!
Last edited by BmainStar; 04-17-2011 at 07:34 PM. Reason: cuz needed a comma,Momma
#6942
#6943
Last spring I raced on a wet morning and had my jammin SCRT come off the track looking like that. NEVER again. Just way to much work to clean that slop up and really stressful on the battery and electronics.
#6944
Yeah you have to run the red wire to the white wire and vice versa on the moter/esc.
I don't remember my settings exactly but I know 0 drag brake, no punch control(max punch), max timing, 50 or 75% brake. All set by ESC, never hooked the Castle Link to it. 18t pinion, Spektrum servo, Airtronics MT4 Tx/Rx
I know I might stur up some ish with this.........but a lot of times when I see people having glitching issues I notice they are running a Spektrum Rx.......just sayin.
