#5416
I have heard some people having issues with the truck nosing down when coming off of jumps and when I ran mine for the first time a couple days ago it was doing the same thing on many jumps. Can anyone give me some ideas as to what I should try to fix this? Maybe raise the front ride height? Thicker rear shock oil? Etc?
#5417
*Track size?
*Pinion size?
*Motor Turn?
#5418
I wonder if every one having this issue is running the 1415 castle?
#5419
I think this truck flies alot more level then the "other guys" trucks .
Heck I almost had to re learn jumping after I started running my Hyper it would nose over so much . After a little setup and practice it got much better .
Is this your first 4x4SCT Ram4wldr ? It takes a little getting used too staying on the throttle a little longer after leaving a jump .
#5420
Maybe more people can add to the list..
Move battery to the rear of the tray.....
#5421
Casey or Ryan,
Can either of you (or anyone else for that matter) post a pic of what holes you open up on the stock body? I opened the row of holes at the lower edge of the windshield and the two big faux fan openings behind the cab. What other holes do you open up?
Thanks!
Thanks!
#5422
Casey or Ryan,
Thanks!
Thanks!
There are spots on the very back end of the body by the rear bumper that you can drill out .
#5423
#5424
#5425
To All...if you check out the Losi page, the new HD lightened outdrives were put up under the whats new section...
http://www.losi.com/Search/Default.a...=LatestRelease
I am not putting this on here as a sales thing, I am simply letting you know they are up as I am sure many of you will want them. I can tell you, it doesnt seem now like we ordered enough...so if you want them, get them on BO. I am having them place another order already as well. And they will be here before May.
Center:
http://www.losi.com/Products/Feature...rodId=LOSB3576
Front/Rear:
http://www.losi.com/Products/Feature...rodId=LOSB3575
Center:
Front/Rear:
#5426
This is my first SC. I have always run 1/8 nitro buggy and truggy. I will have to try staying on the throttle a little longer after the jump. I have zero drag brake in my setup. I am running stock shock oils. I have a RX8 / SC4X 5.5 in the truck w/ a 14t pinion. Battery is all the way back.
I run on large outdoor 1/8 style tracks and the jumps are mid size to large.
Hopefully this information will help some of you give me some advise on things to try to get the truck to not nose down when flying off of jumps.
#5427
Sweet. are these harder than the regular ones? The regular outdrives are way too soft (at least the ones I've got on my cars as they have shown quite a bit of wear).
Center:
Front/Rear:
Center:
Front/Rear:
#5428
Center:
Front/Rear:
Center:
Front/Rear:
#5429
I just comes to basically "drive it like you stole it" at least on our fast outdoor track. even the slightest hint of backing off when it was a high speed jump resulted it diving.
so keep it squeezed to the grip in the air on hi speed jumps and it usually works for me...
