Yea i was thinking about that your guys trucks are lighter than my. So #3 pistons 30w orange rear springs ? If that doesnt work than il do the meduim black rear springs not the stock ones. Im running on a large outdoor offroad track with some big jumps so im thinking that #3 pistons would work better.
Also do you have the number of the piston faceing up top or the bottom because it looks like the side with the number on it the holes are bigger.
Wheels are 7mm nut driver as they are 4mm nuts. (get serrated nuts for this car so they stay on when the nylon wears out! )
I always put the number up so I can see the number when I rebuild the shocks but just a habit thing. It should not matter.
Shock nuts (and all 5-40 nuts for that matter) are 1/4inch nut driver.
Ok thanks well i dont have 30w for the rear shocks the heavyest i have is 32 1/2 w oil. So it would be 30 f/#4 pistons and 32 1/2 #3 pistons i guess that would be fine for now im not running on a bumpy track so.
MY track is covered with snow.. do you think I should try running my scte in that.....?Attachment 990806
Nope you get yourself one of these ! Click on the pic for video of it in action .....
Thats 1 thing i miss about my Traxxas Slash...ran it stock with paddle tires and it was a blast, didnt need to go fast, just out tooling around with the fam(bro-in-law, nephew, and buddy). We also ran nimh batts and kept the lipos inside but maybe one day when i can swing it i'll buy something like that again but the way its going maybe Losi will have an all waterproof truck/something so i dont have to go back to Traxxas
New SCTE spotted
Went and ran nitro today at Reveleation raceway in Pomona. Was told Losi was there this past week testing and shooting pictures of the new truck. Was told it's about 1 pound lighter,Reconfigured chassis,No battery tray just fore and aft blocks that lock the pack in. All the TLR parts including front and rear pin holders ETC. New tubular chassis braces. This guy said it looked real good on the track. I for one cannot wait! Supposed to be released sometime in January,but we all know how release dates get pushed back over and over. Anybody got any more info on this new one??
Mark Smith
Mark Smith
I can see why you guys say go with the no bladder emoulsion setup on the shocks the bladders are not that good on this truck .
It was having diffrent rebound every time i push the shaft up. But im racing tommrow with that truck and i think i will go with the Emolsion shock setup.
Guys what are some of the secrets to getting weight out of this truck? I'm running the stock roller chassis with stock plastic braces. Also running a carbon fiber center diff top plate and carbon fiber losi towers. I currently have a 4.5t 550 can motor with a 1/8th esc. Running hardcase 2s lipos. Already have trimmed the rear bumper and I'm running a jconcepts body.
Swiss chesse the battery tray , cut side nerf bars off, trim rear bumper as mentioned, ditch the radio box but keep the servo mount side, use s 540 can instead of 550 can motor, hd outdrives, aftermarket chassis ( of choice) ti screws n tie rods, thats basically it
Thanks!
I'm running on carpet and I'm using the stiff gold springs in front, with the shock-collars in the upmost position the front-arms are parallel to the ground. I'd like to have the truck a bit lower even. I learned that to modify ride-height you change the shock-collar height, but since they can't go any higher - what's the appropriate way to lower the ride-height even more ?
http://www.rctech.net/forum/attachme...1&d=1352641202
Cut a lot of holes in battery tray to lighten up its a big heavy chunk of plastic
Cut the side handles off on mud guards
