http://www.ebay.com/itm/Integy-Super...item3377bba8cf..
scte running hot try this.. I have been using one for a yr helps with temps.. you dont have to buy this one. but it gives you an idea.
Anyone got the kingzhead chassis?
IF SO, then does your motor just sit there free? Theres no plastic piece or anything under it on that chassis?
Fill with oil. to 1/8 inch before top of shock body with shaft all the way down. start cap with hole facing to the top at a 45 degree angle with cap just started push shaft in all the way in whyle holding shock at angle with hole to bleeder facing up. screw the shock body and it will puff the air out. do this two to three times and tighten when your done at same angle. takes a few fingers to get er right and sometimes you have to do it 4 times.. once you can go up and down with out sqeeeeking your good.. I use no rebound and found that works great you can adjust the shaft to your liking when building Hope this helps. I also cut the bladders. Casper or some one has a video . maybe they will post it for ya.
That's a great post. You know, since SaladFork bailed on us ... I wonder if we can get someone who has a post on the first page to volunteer to modify it and include FAQs.
KingdomRacer has post #2. What do you think Kingdom. What if someone spoon fed you that data. Would you copy and paste it into your post?
I run the kingz Head chassis and am not sure what plastic piece your talking about. What do you mean by the motor being free? The chassis is a direct replacement for the stock. Post a pic if you can.
I also see Hypers and Jammins always on the for sale thread after the owners get smart and buy one of these!
Oh cobraman got me the answer. There is a composite piece that goes on the original chassis, has a small plastic tab like object that comes out of it and seems to support the motor, jsut wondering if that was needed.
Cool, right on. I love my K.H. chassis.
thinking about going with the BigBore shocks on my SCTE , what are your suggestions? read here and there the Kyosho are recommended , which of them? any other suggestions? what about emulsion style on these? anyone attempted this mod on BB?
Hi there everyone,
Long time had not been on these pages.
Quick question: I am running a MMP SCT + 2400Kv on 3s and starting to find the right settings on the ESC. I have bought these pistons (M2C Racing tapered). It is stated that the tapered hole should face down... Is the tapered side of the hole the smallest OR biggest hole? Sorry I am not english fluent.
Thx for your feedback.
Best,
V
Best,
V
