The MMP is not the cause from what I have found. When I ran savox, MMP, spektrum it happened every time car was ran. I then switched to KO and all was fine.
MMP gets a bad rap and while BEC might be subpar, it's really a spektrum issue due to their piss poor voltage fluctuation problem.
Glitch buster will help as long as you set servo endpoints correctly. I never had to run a external bec.
Some guys have different results.
Having said that I'm not running Savox or Spektrum, but still had glitching problems.
On a related note...
BlackStarRacing or RocktheCatBox - do you need to run an external BEC with your Hobbywing SCT Pro ESC? Or is the internal BEC enough? I am about to buy another ESC anyway, so was thinking of trying out the HobbyWing.
Actually, it seems to be the combination of all 3 products - from what I've read, most people who have just one of those components (servo, esc, receiver) different seem to have their problems fixed?
I'm not sure this result is typical but I just switched to a 7k center and drove my temps up 10'. Now I'm on a loose track so maybe the two items combined to drive temps.. seemed like I was spinning my tires a bit more w/ the 7k. Steering didn't seem too impacted.
You should give the no sway a shot quick.. it's the only way I run anymore
I agree with this. The savox + spektrum + castle combo has had a lot of reports of brown outs / glitching.
Does the problem happen when you suspend the car so that none of the wheels/tyres are touching the ground? It should be virtually silent. Then, with your hands off the transmitter (but everything on), start to turn the front wheels of the car so that the servo needs to resist your movements. This will make the servo draw current from the ESC. Apart from some humming from the servo, you should not get much glitching / twitching. If you do, it is because the BEC is overloaded and shutting down.
I used a Novak capacitor to fix this for my Mamba Max Pro, but a sure fire way to fix this for a couple more dollars (and some more soldering) is a separate BEC.
I picked up an SC4x 4.5 tekin in a trade, I was wondering if a 13t pinion was a good starting point for this motor. I'm running a 14t with my 3800kv castle on a tight outdoor tack, the longest straight is probably 40/50 foot max. And where should the endbell timing to set at?
Castle said it was because I was running 2s and the BEC was seeing a voltage sag which was causing the BEC too "drop out" which in turn was causing the RX to go into failsafe mode . I now run it on 4s in my 1/8 E buggy and it STILL needs a BEC too run right . IDK maybe the BEC is damaged in mine ?
I ran the Mamba Monster on 2s and it did not have the same problems as the MMP did . IDK if they have remedied the situation yet or not .
I am one of those guys Tried 4 different ESC's(Novak Havoc SC Pro,Castle MMM,Castle MMP,Tekin RX8) and the only one that cut out was the MMP , and I tried 2 of those . All were ran with the exact same equipment (servo,motor,batteries) Both MMP's cut out and needed an external BEC to run correctly .
From what I understand that cap pack is only to smooth out the ripples in the voltage that can occur under heavy load and that would not help with the BEC issue.
Have you MMP guys tried a glitch buster?
I HAVE to use one in my 22 cause i use a savox servo. If i dont use it, it glitches out like crazy standing right over it.
I did and it still cut out .
I run a HW SCTPro ESC/Tekin Pro4 and Savox and still need a CAP or Glitch Buster.
The BEC in the SCTPro is not enough when using the Savox Servo.
