Like Tree9Likes
Old 10-13-2011, 02:47 PM
  #22171
dtr
dtr's Avatar
Originally Posted by rcguy76559
m2cracing link doesn't work
Just add the second c: www.m2craCing.com
dtr is offline
Old 10-13-2011, 03:03 PM
  #22172
mjealey's Avatar
Originally Posted by vasidudu
hi there,
just received 3 x 6000mAh 2S LiPo
waiting on 17T and 19T mod 1 pinion + ofna adapters, Losi carbon shock towers, CC BEC.
then soldering and GAZ!
can't wait to try this on our 1/8 track
http://team-craze.blogspot.com/
big up for the guys that take the time to help by answering
good WE to all
V
What motor and ESC combo are you running? That is some pretty high gearing and I doubt it will work (temps) on 2s. Highest I have been able to run is 15t. I would probably advise against that gearing!!! When I run on a huge 1/8 track I run a 15t, other than that usually a 13t!
mjealey is offline
Old 10-13-2011, 03:20 PM
  #22173
Trader Rating: 23 (100%+)
Originally Posted by Wheelman82
Ok thanks i did buy a Futaba one made by racers edge idk why it wont fit oh well thanks mjealey
It will fit. Savox has a real tight fit though. Seems like it wont go but if its 25t it will just put some effort in it lol
nitro0619 is offline
Old 10-13-2011, 03:28 PM
  #22174
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
The Novak Ballistic 4.5 with the HT rotor can pull those pinions.
ChrisAttebery is offline
Old 10-13-2011, 03:34 PM
  #22175
vasidudu's Avatar
well there you go i learn everyday
i am running CC 1415/2400Kv and MMPro SC Edition.
think i was "advised" earlier to go for these pinions' size with that combo.
understand though a 2S is a little on the low side for the motor but i am not really into speed runs.
idk maybe i am wrong.
any advice anybody pls?
thx,
V
edit: AAAAAAAARRRRRRRGGGGGGHHHHHH... feels like i am going to have to order different size pinions?
edit 2: found this on the first page:
Castle/Neu 4 Pole motors
Castle 3800kv - 13-18T pinion
Castle 2400kv - 17-23T pinion (20 tooth and beyond you need the ERC motor mount).
vasidudu is offline
Old 10-13-2011, 03:53 PM
  #22176
DBL15's Avatar
thx,
V
yes mate the 1st page is where most up to date information is found , 80% of this threads questions are all answered on the 1st page but everyone goes straight to the last page and ask's questions
DBL15 is offline
Old 10-13-2011, 03:59 PM
  #22177
SaladFork's Avatar
I will admit I have been slacking on the first page... I do plan on moving all that info to a webpage when I get a chance. I can not STAND the VB formatting, its SOOO limited without CSS.
And if anyone was looking to see how fast the VX4R51 is, here is a video of "The Crazy One" 5150kv 4 pole 540L, 140 all day long with a 14T.
+ YouTube Video
SaladFork is offline
Old 10-13-2011, 04:03 PM
  #22178
vasidudu's Avatar
thx there.
so i am cool running 17T 19T pinions for a starter on a mid size 1/8 track?
thx for the input,
V
edit: hey DBL15, was in coolangatta last summer (winter for you)
will probably be here again this Xmas
QLD rocks!
vasidudu is offline
Old 10-13-2011, 04:08 PM
  #22179
SaladFork's Avatar
thx there.
thx for the input,
V
I tested the 1410 and 1415 this might help... Running the 1410 on 2S with a 18T pinion top speed was 37.8mph. Running the 1415 with a 18T on 3S (same gearing) the top speed was 37.1mph. Bottom end on the 1415 on 3S was much more powerful on the low end and better run times. To match the speeds of the 1410 on 2S you will want to get a 19T or 20T.
Old 10-13-2011, 04:10 PM
  #22180
Bondonutz's Avatar
Trader Rating: 48 (100%+)
hi there,
good WE to all
V
No clue what motor your running but I smell smoke already ?
EDIT; As I read further I see your running the 1415 2400kv, you could safely gear up with a 20T and be OK, Have fun !
Bondonutz is offline
Old 10-13-2011, 04:16 PM
  #22181
vasidudu's Avatar
thx bondonutz and saladfork
always great to have expert advice.
waiting on my 19T then
best,
V
vasidudu is offline
Old 10-13-2011, 05:06 PM
  #22182
dumb question but how are you guys mounting the pro-4 motors? I looked at mine and in order for it be mounted with the solder tabs vertical I have to use larger screws(but they don't fit the losi mount(do I need to rotate the front of the case or what?
NitroLuver is offline
Old 10-13-2011, 05:14 PM
  #22183
Integra's Avatar
Correct. Rotate away.
Integra is offline
Old 10-13-2011, 06:10 PM
  #22184
Mine points toward the outside of the body at about a 45 degree angle. It's a good question, I need to get some other screws to rotate vertically.
coffee is offline
Old 10-13-2011, 06:21 PM
  #22185
DBL15's Avatar
thx there.
thx for the input,
V
QLD rocks!
very nice place place hey i live about 15 mintues away from there
our winter would be a summers day for you wouldn't it
yeh i think you would be fine with the 19T depending on track size even up to a 20 on a 1/8th track
DBL15 is offline
