Since these are 8 hole pistons, would you have to run significantly heavier oil than with the stock pistons?
5/64 axle drive pins for the SCT E
got my new sct E truck and the first thing I did was to change the tires.
Well, pulled the wheel off and the Hex stuck in the hub.
Of course I didn't pay any attention to the pins so when I go to put the new tires on guess what. No pin in the axle.
And perhaps they are somewhere on losi"s site, but I couldn't find them with our buying the drive axle. I have heard that this is a problem with this item not being sold seperately.
These pins are hardened dowel pins and should outlast the truck.
note: I haven't checked but these pins will probably fit about all the core trucks.
These will be packed in pks of 4.
part no m2c7120
Anyone know what size aluminum servo arm i need for a savox sc-1258tg. The one i looked up dont fit so im stuck with plastic till i find one. Thanks guys
http://www.amainhobbies.com/product_...ervo-Horn-Blue
Yep, buy any servo horn for a Futaba servo they are both 25t! Here is one example:
Thats not the case with myself. I think I have the lightest Losi I've seen, and I race almost entirely on huge outdoor 1/8th scale oriented tracks with monster jumps. I have yet to see a situation where lighter wasn't better with this truck, but you keyboard jockeys that have never ran one this light can just keep talking.....in the meantime I'll just keep winning!!
Good news for all of you though.....Denial is the first step to recovery!!
Have mine all torn down now have some things on order just wondering what all I need.
Thanks for any help.
Thanks for the all the help guys....Time to practice some solder skills before the finally putting everything together getting closer to be able to finally run this bad boy cant wait
Lightened HD outdrives
Carbon Fiber towers.
Lightened Chassis (BCE, Losi, Bump, etc..)
540 4poles
Cut off the plastic handles on side
Cut the rear bumper sides off
Losi aluminum hinge pin holders
I have done this and my truck feels pretty dang light! Also get rid radio tray, cut the battery tray. A few other things but these are the major things to do.
hi there,
just received 3 x 6000mAh 2S LiPo
waiting on 17T and 19T mod 1 pinion + ofna adapters, Losi carbon shock towers, CC BEC.
then soldering and GAZ!
can't wait to try this on our 1/8 track
http://team-craze.blogspot.com/
big up for the guys that take the time to help by answering
good WE to all
V
good WE to all
V
m2cracing link doesn't work
