Searching has been a lost cause in this thread. How are you guys setting up the adjustments on the hinge pins on the Tuning kit?
what length screw and what countersunk washer are you guys using for the motor mount mesh adjust screw?
1's up in the front and 0's in the rear for the rear settings.
JayL the screws and part numbers are in the manual that come with the truck.
Just got the truck!! In fact my first Losi ever.
Motor/servo should be here this week and I already painted the body.
In the meantime, what else besides diff I should go over?
I'm going 5/7/3 (f/c/r) for a big outdoor 1/8th track a little loose with big jumps. Any other thing I should work/replace? And what about holes on the body, more besides the ones on the windshield?
Putting an order for 4-40 x 1/8 Button Head Screw (LOSA6212) because there is already a dent on the chassis out of the box.
Ok I know what you are talking about. Sorry. I use 5-40 cap head screw and #4 washer so you can use the larger 3/32 wench instead of a smaller 5/64/2mm. I don't remember the size but the same size as the button head. I think 3/8" length should work?
Hey what`s up Jayson? Not sure bout Rev but sounds like a good idea! And will check the track 2-maro or wed nite practice and report back! Stay FasT!See ya Soon bro!!
I've packed mine with grease and put a boot on it since day one and it still looks new. But the pin on the dogbone side that rides in the outdrive is worn.
i just tried to install my lightened center outdrives. when putting back together i noticed i had to re-shim my diff. i tried several diff shims and found that with no shims at all in the diff it felt better but still wasnt good enough. is anybody else having this problem? i even reinstalled the stock outdrives with the shims i had in befor and it felt perfect
I put these on my truck this weekend. They are TOP NOTCH! quality and fit is perfect and dead on. I've had that pin push out of the plastic sleeves so many times that I don't want to post it and have spent wayyy too much money having to replace them. I bought these and I'm confident that this will be solving the problem with the pin pushing through the sleeve.
I think this should be front page material because this is a very common issue. I will say though, since I lubed cv last time I changed them out, this hasn't happened, but now this sleeve is insurance that it wont happen again!
R/C Tech Elite Member
To the person that posted that new painted body by paint monster, Looks amazing I'm going to have them do a body for me after seeing that. How much does it cost ?
Also Is the Castle 1415, 2400kv motor a 540 or 550 motor?????
- its 69.5mm so I would think its a 550 size motor?
Also does anyone run the 1415, 2400kv and Mamba max Pro in there Scte??
- This is the setup going into my truck on 3-4s. I may upgrade to the new tekin 4600 and run it on my MMP.
On 3s it will scream...that's what it's best with
I am buying my tools for working on my SCTE. What size turnbuckle wrench Do I need?
How many guys can make a 10min main?? If you can what motor and speedo along with battery mah are u using.
