I am running the Aaron Lane setup and it calls for full droop for the front and rear.
With 8ight shocks, I back the droop off some for indoor, but go full droop (close to half an inch more than stock) for rough outdoor.
If my o-ring lid is correct...meaning I took what I think I did out of bin. The o-rings for shock caps are 9/16x7/16x1/16. I'm pretty sure that's right, without opening up shock.
Ya, full droop in the rear too!!Backed off the eyelets 2 turns as well on all 4.I installed new orange rear and blk frnt springs as well.Truck had just got the new TLR chassis and didn't want to scratch the droop spots Fri nite , so back up the rears too.Truck ran so good, I keep walking out to the garage just to look at it Is this NoRmAl ?
Whats the scoop on the bearings in this truck, did they go cheap on them, do they wear out quickly for some reason, or maybe I just got a bad set?
I have yet to check all my bearings but I pulled my diffs out and 3 of the 6 were starting to go bad after only 6 packs?
Anyone else think these are wearing a bit prematurely, is it more then just the diff bearings?
sweet, thanks man. do you think we can run a 2nd o-ring, at the base of the threads on the shock body, much like an AE FT V2 shock?
I've had good luck with my stock bearing also, minus the front center diff. I bought replacements on eBay and have only used the one. I run mostly indoors so not much dust or dirt, but when I do run outside I make it count.
Can someone please confirm or point me in the right direction for this:
Are these the aluminum shock caps that now come pre-drilled with a bleeder screw to run emulsion or if not, which ones do?
From what I've heard this was a running change, so you may or may not receive the update caps with the bleeder hole. I have the caps without the bleeder hole and still haven't had a chance to install them.
I believe Ryan was offering to drill them for you if you sent them in?
yes but you could get the older one that doesn't have bleeder hole.
