Like Tree9Likes
Old 09-16-2011, 10:28 PM
  #20296
Grandturk's Avatar
Tore my truck down tonight and found 6 seized bearings - the big ones on the front diff, and one set on a front axle and one. On the rear. Gotta make a shopping list for replacements.
Any hope of "fixing" a seized bearing by blasting it out with wd40? Or is it easier to just replace the stock bearings?
Grandturk is offline
Old 09-16-2011, 10:30 PM
  #20297
rcguy76559's Avatar
Trader Rating: 22 (100%+)
Buy new bearings there a buck each. Avid is pretty good
rcguy76559 is offline
Old 09-16-2011, 10:50 PM
  #20298
jhautz's Avatar
Trader Rating: 86 (100%+)
Originally Posted by rcguy76559
Dang 6hrs that's a lot of time. I work 3rd shift get home shower change and eat. get my rc bag and head straight to track to race saterday morning no time to sleep. Lol
I need my beauty sleep.
jhautz is offline
Old 09-16-2011, 10:53 PM
  #20299
Does anyone know what size bearings go in the Castle 1410 and where I can get them at?
mxr300ex is offline
Old 09-17-2011, 01:50 AM
  #20300
They make a rebuild kit. Saw a bunch on ebay.
SC_RAGE is offline
Old 09-17-2011, 04:15 AM
  #20301
ffpm46's Avatar
Trader Rating: 179 (99%+)
Originally Posted by Feint Motion
^^This- Do this and your leaking diff problems will go away. No need for oversized O-rings, etc..
Also sand your diff cases.
So we glue the inset in with CA glue, that's it?
ffpm46 is offline
Old 09-17-2011, 04:25 AM
  #20302
rsr14's Avatar
Hi Guys,
I am about to buy some upgrades for my scte. Budget is $250. What would be the best performance increase for the buck? Currently it is all stock chassis with chrispins, MMP, castle 1410 and a soon to have nanotech 6000. I was thinking the TLR chassis and tuning kit. Any other better combinations? Titanium links instead of the tuning kit? Also, what spare's would be suggested? Haven't broken anything yet in a handful of races but I'm sure its only a matter of time.
rsr14 is offline
Old 09-17-2011, 06:00 AM
  #20303
I thank you for trying to help, but those rebuild kits are $40 or more. I just ant to replace a sloppy bearing.
mxr300ex is offline
Old 09-17-2011, 06:42 AM
  #20304
10sctrel0v3r's Avatar
yes, it will stop the diff fluid from seeping out around it and also it will keep that insert from slidding into the diff case like some of us had it do previously.
10sctrel0v3r is offline
Old 09-17-2011, 06:54 AM
  #20305
I pulled the bearings out of my Castle 1410 and they measure 5X14X5mm. Just thought I would share this info in case anyone else needed to replace theirs. You can get them here http://www.vxb.com/page/bearings/PROD/5mm/605ZZ30-1 .
mxr300ex is offline
Old 09-17-2011, 06:59 AM
  #20306
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Smile Now you tell me....
Hehehehe... Well Guess i'll try this and some new dif fluids. Just rebuilt them all and was not sure where the fluid was comming out. Thanks!
XXXDad is offline
Old 09-17-2011, 07:32 AM
  #20307
your welcome
Old 09-17-2011, 08:56 AM
  #20308
dtr
dtr's Avatar
Originally Posted by jhautz
anyone know what size the dif o-rings are? My difs are leaking like crazy. ...
In addition to the glueing I suggest using some thick grease, e.g. LOSA99203 below the o-ring and in the groove on the outdrives.
dtr is offline
Old 09-17-2011, 09:04 AM
  #20309
rcgod's Avatar
Trader Rating: 33 (100%+)
Originally Posted by rsr14
Hi Guys,
The tlr chassis is nice but u will have to use the factory plugs and pieces under the diff unless u want holes in the chassis. Bce or bump chassis eliminate them and saves some weight. I would go with the tuning kit and aftermarket chassis.
rcgod is offline
Old 09-17-2011, 09:09 AM
  #20310
rcgod's Avatar
I used jb weld. I wasn't sure how well ca would hold on the steel. Also make sure the insert is fully bottomed out before the glue sets up. If it's not your gear mesh will be too tight.
rcgod is offline
