TLR 22 Racing Buggy Thread
I;m running the Evan's Reedy race setup on a medium to high grip track. Running in the 17.5 class with a Ballistic geared at 72/32 (associated spur), brass 25* front shim, Double Dee's on the back and Groovys on the front. I just can't seem to carry the speed through the corners that the fast guys can due to an on power push/ not enough mid corner steering. Just wondering what I might be able to change to try and combat this. Thanks in advance for any help.
Thanks for the input. I got back in to the hobby after a 15 year break. Spent the most of this year trying to get consistent. The consistency is here just need to reduce the lap times now.
Ive found that staying on the throttle through a turn gave me a more consistent turn. I.didn't spin out as much on exit. Ill let off entering but keep some throttle input. So technically it still on power I guess. But getting back on can still be tricky. Depending on traction.
SPINDLES
HEY GUYS WHAT DOES MOVING THE SPINDLE SHIMS DO TO THE CAR ,YOU KNOW WHAT DOES THE SPINDLE CENTERED DO TO THE CAR VERSUS BEING ALL THE WAY UP OR DOWN
Front Spindle Location : running spindle higher acts similar to limiting the front shocks, a noticeable increase in mid corner to exit steering
What position r u guys running your wing in. And what helps what?
Its a simple thing about physics and on / off throttle weight transfer.
The less you come on and off your throttle, the less your car will transfer
Its weight and upset the grip of the outer tyres.
TLRacing
Spinning out
Recent changes raised tranny 1mm, standard battery and 3.0 lrc (Chambers set set up). Was at WEST COAST last night, and the car kept over rotating when turning and spinning out. It happened at the end of the straight and 180 turns. First I tried to roll into the turn with no break off gas (no drag break). Didn't work. Then tried to tap the break, only got worse.
I need suggestion to correct.
R/C Tech Elite Member
There can many things, but I would start with tires and maybe a little too much drag brake.
can someone recomend a link for a high bite, tight, indoor carpet track set-up for a rear motor set-up. have the rtr 22
having a terrible time searching for something
thanks in advance
thanks in advance
This is a really good start to a high bite carpet setup however all carpet tracks we have here are raced in mid-motor.
