TLR 22 Racing Buggy Thread
New
Hey RCTech how's it going? I'm new to this forum as you probably can tell,lol.. Just want to use this a educational site on my buggy and will sit in and read questions every once and a while.. So far I have read and learned a tremendous amount from individuals on this forum. Keep them coming,lol.. Later...
I'm running on a fairly smooth track with a whoop section that is kicking the rear out on the last whoop. I'm running kit springs with 55s (f/r) with 27.5 front and 25 rear. I'm thinking I'm getting too much pack out back and was going to try 54 pistons or 22.5 with the the 55s? Any recommendation on which way to go?
Madweazl- a wise man once told me, don't tune your suspension for one part of the track, tune it for the majority of the track.... But with that said ... 54's with 30 wt oil would probably help in that section
video
Here is a video of my friend with his new Losi Racing 22 buggy at our new local indoor track. Thanks and enjoy.
http://www.youtube.com/user/nickcatt.../0/ggytqNLkJnE
TLRacing
Did anyone have rubbing between the caster blocks and spindle itself. Thinking about taking the dremel and taking a little plastic away to take the tension away.
quick question. I am trying to match the Dustin Evans setup as a starting point for my new 22. I think I have everything set but I dont see on the setup sheet if the short battery is supposed to be run forward or in the back. Also, what are you guys using for spacers to take up the extra room in the battery tray. Some kind of foam block I assume, but does anyone have anything they found that works well and is easy your hands on. Im not finding anything good in my Pile O' RC junk that seems like it will work. Im considering just cutting a chunk of styrofoam from some packaging and sticking it in there. Just wanted something that may look a little better than a white chunk.
Thanks in advance guys.
If you move the plastic battey tray to the rear chassis holes you will end up with one "fresh" foam pad behind the battery and the battery up against the tray.
This has always given me the most rear grip.
Adding a second foam pad behind the battery gives more steering and makes the car too loose for me to drive but is the preferred position for many of the top drivers. Now that the optional aluminum battery tray is available it is easy to choose between the 2 positions using either of the 2 sets of mounting holes.
any part(s) numbers for the gear diff we are supposed to use?
thanks!!
thanks!!
Well I had my first race night with the buggy on Wednesday. Ended up 2nd in the A main just behind a very good sponsored shumacker driver. The 22 ended up having the fastest lap and the fastest 5 10 and 20 lap averages however I got hacked out by traffic on the first three laps. After the race I realized the little screw holding the rear toe plate in the middle backed out and I noticed the rear end catching things here and there but I just assumed it was rocks lol. Oh well screw is replaced and all is well. Outset of the snagging once it fell out I'm not sure if it even affected the buggy at all. I need to tune the driver a.little more as I only had 2 battery packs worth of practice prior to the race day so it will get there. Hopefully next week ill have lady luck on my side. Love this thing.
