TLR 22 Racing Buggy Thread >
Like Tree1Likes
Old 10-02-2011, 11:05 AM
  #10291
Potoczak's Avatar
Trader Rating: 120 (100%+)
Hey guys what would be the best starting setup for a high grip indoor carpet track??
Potoczak is offline
Old 10-02-2011, 12:08 PM
  #10292
rcjunky1's Avatar
you want to use the set up JAUNE posted here
http://www.rcottawa.com/forum/index.php?topic=8779.105
with 27.5wt and #55 pistons. His car is fast. Mid motor with the stubby lipo.
rcjunky1 is offline
Old 10-02-2011, 03:05 PM
  #10293
opio's Avatar
Hey guys/gals, still wondering if there is any word on a shorter chassis not limited to mid motor? I have heard of a couple, but there for mid only as far as I can tell. Thanks
opio is offline
Old 10-02-2011, 03:06 PM
  #10294
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Guys, AE spurs work on the 22, w/o mods right?
yyhayyim is offline
Old 10-02-2011, 03:08 PM
  #10295
opio's Avatar
I believe they do. Worked just fine on cr and I'm using my spurs from my cr.
opio is offline
Old 10-02-2011, 03:25 PM
  #10296
F N CUDA's Avatar
Trader Rating: 34 (100%+)
The hex for the pads on the AE spur is larger than the slipper plates on the 22 so if the pads are worn or compressed below the hex then the plates will touch the plastic on the spur's hex.
The popular conversion is to use all AE plates, spur and pads.
Correct me if I'm wrong.
Personally I "stretched" the motor screw slots and squeezed in a 35 pinion with the stock 76 spur for a 17.5 no timing setup.
34 pinion will fit with the stock spur with no "love" needed on the motor screw slots.
F N CUDA is offline
Old 10-02-2011, 03:35 PM
  #10297
opio's Avatar
You are correct sir, I use the ae slipper pads and plates on the cr. Forgot about that.
opio is offline
Old 10-02-2011, 04:44 PM
  #10298
The Akula graphite chassis kit is either mid or rear. i have one setup on rear motor.
The downside is the cost. $135 euro's or 220+ us. i have contacted SNR graphite about producing a similar product. you might want to email him and show your interest maybe he will consider it....
sjenkins97 is offline
Old 10-02-2011, 08:57 PM
  #10299
porkchop's Avatar
where do i get a 78 tooth sper gear?
porkchop is offline
Old 10-02-2011, 09:02 PM
  #10300
Trader Rating: 96 (100%+)
Pretty sure i saw an alloy one in a post on the oOple forums that was anodized black and 8 or 10mm shorter. Even if it's midmotor only I think you only have to drill and countersink two holes. Maybe four at the most. It's also a UK part so you'll get killed on the exchange and shipping. I was thinking about cutting one down and getting it TIGed back together.
Eric Tomczyk is offline
Old 10-02-2011, 09:07 PM
  #10301
STLNLST's Avatar
Trader Rating: 32 (100%+)
AE makes a 78 spur. That's what I'm running on mine.
STLNLST is offline
Old 10-02-2011, 09:11 PM
  #10302
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
http://www.horizonhobby.com/Products...ProdID=TLR3980
Also, call around your LHSs, one of them is bound to have the old Losi spur which is the exact same thing.
T-BirdJunkie is offline
Old 10-02-2011, 09:42 PM
  #10303
porkchop's Avatar
ok guys i ran a 7.5 with a stock gear and a 22 pinnion i think sat it was good but the track i was at it was way to much motor.
i want get a 9.5 can some one recommend a good starting gearing?
porkchop is offline
Old 10-02-2011, 09:52 PM
  #10304
If you liked the 7.5 with a 22 tooth pinion, then try a 24 on the 9.5.
Old 10-03-2011, 05:47 AM
  #10305
If you look at the New Products page of the TLR website a 70t Spur, black body clips, and wing washers have just recently been released. A 78t spur is available but may be on back order at the moment.
M Chambers is offline
