TLR 22 Racing Buggy Thread >
Like Tree1Likes
Old 03-17-2011, 05:24 PM
  #2791
NoobRCDriver's Avatar
Originally Posted by NNRC
Here's mine
Nearly completed, just need to install the ESC & RX tomorrow night. Then set all the geometry up.
Nice easy build.
AH man! you're kickin us where it hurts.. Gratz! btw...can't wait to get mine!
NoobRCDriver is offline
Old 03-17-2011, 05:36 PM
  #2792
Trader Rating: 77 (100%+)
Default tires
What are those tires good for? Those look crazy.
goin2drt is offline
Old 03-17-2011, 05:40 PM
  #2793
Muggydude's Avatar
Trader Rating: 92 (100%+)
I'm pretty sure they're for Astro turf, which many UK tracks are made of. He must be in the UK to have one already.
Looks great, seems as if they're will be enough room for a small rx and small esc (Like the Tekin RS) in front of the 96mm pack! I never liked putting the esc on the motor like Losi recommends because of the heat.
Muggydude is offline
Old 03-17-2011, 06:28 PM
  #2794
carcrusher46's Avatar
Trader Rating: 17 (100%+)
I'm trying to figure out how Europeans get a kit from an American company before Americans do.
carcrusher46 is offline
Old 03-17-2011, 06:31 PM
  #2795
Joel Lagace's Avatar
LOL They are not "Made in America"
Those are shumacher tires. WE run the mini pins at our carpeted indoor offroad track amazing tires.. would never have thought a tire that hard could work on carpet but it does..
Joel Lagace is offline
Old 03-17-2011, 07:02 PM
  #2796
I never said they were made here - just that it's an American company.
Everyone's buggies look fantastic - they look extremely planted on the track!
Old 03-17-2011, 07:17 PM
  #2797
t8rtot's Avatar
Trader Rating: 14 (94%+)
LPF servo plus 96mm battery.. Shouldn't be a problem getting an average sized ESC in there.
t8rtot is offline
Old 03-17-2011, 07:45 PM
  #2798
Bobby Z's Avatar
Hey Joel
Are you running mini pins in the front on the track in Ottawa or stagger ribs? I will be running on carpet as well when my 22 comes in and I picked up some yellow minipins for the rear and yellow stagger ribs as this is what I used in Toronto at Fastcats before they closed. No one could get mini pins to work at Fastcats but it was large for an indoor track with many sweeping corners. The track I'm running at now is smaller and more technical so I think minipins will be better with maybe the outer and inner rows of pins removed to maintain some stability. Any suggestions?
Bobby Z is offline
Old 03-17-2011, 07:54 PM
  #2799
Trader Rating: 28 (100%+)
Default TLR 22
I KNEW IT! HORIZON JUST PUSHED BACK THE DATE TO MAY 2011!!!
T
mxtoeknee is offline
Old 03-17-2011, 07:55 PM
  #2800
Default TLR22
Just kidding... Sorry guys, just had to do it!
T
Old 03-17-2011, 07:58 PM
  #2801
Trader Rating: 90 (100%+)
T
Dude, that's not right!!!!
b121774 is offline
Old 03-17-2011, 08:01 PM
  #2802
Originally Posted by tripthreat
Hey Guys,
Sorry but I have been off-line the past few days.
1. I am running Mid-Motor
2. I am the only US Team Driver Running Mid-Motor.
3. Dustin definately ran Rear-Motor for Reedy, and ever since.
4. The TLR team will all be running Rear-Motor at Cactus this week, with me being the only exception starting with Mid-Motor.
5. The Mid-Motor car has been very good. It doesn't "feel" as dialed in as the rear-motor setup, but I am still tuning in the setup. With a mid-motor car, even the setup doesn't feel 100% yet, I am still doing faster lap times and qualifiers than with my rear-motor car.
6. Setup wise, I am very similar to rear-motor. The front is the same except I went to 56 piston/25 wt. instead of 55/27.5. The rear I am at 25 (27.5), the shock is inside on the tower (middle), hubs back (middle), and 50g of weight on the rear shock tower (14g behind the ESC). Rear motor is ().
Hit me up with any other questions!
Frank, could you please clarify "The rear I am at 25 (27.5)"..sorry, is that suppose to be 55 piston/27.5 wt.?
Old 03-17-2011, 08:05 PM
  #2803
wrightcs77's Avatar
Trader Rating: 551 (100%+)
I think he means 25 wt for mid motor and 27.5 wt for rear motor. I think the notes in parenthesis are what the rear motor standard set up is.
wrightcs77 is offline
Old 03-17-2011, 08:54 PM
  #2804
2 pads rear, 3 pads front.
Frank,
Not quite sure what you mean by 2 pads rear, 3 pads front? How big are the pads? Any pics? I have the batteries already I just want to make sure I'm clear when I start the build.
sak13 is offline
Old 03-17-2011, 08:57 PM
  #2805
Trader Rating: 29 (100%+)
He's talking about the foam battery spacers you normally use only one of with the larger batteries.
JustMe2 is offline
