TLR 22 Racing Buggy Thread
I have always found a stiffer front spring to have less aggressive low speed steering and less chassis roll to the front end. It will also make for a slightly wider turning radius.
With the 22, I prefer the orange (stiffer) front spring on larger tracks with more flowing turns. For tighter tracks I prefer red (softer) front springs as they have better low speed steering.
Give both a try and see which works better for you and your particular track.
Running my 22 for the first time in about an hour, at the local track. A buddy w/ a B4.1 talked me into getting into 2wd buggies. I loved his car and can't wait to beat him w/ a Losi! Lol
Wow! Perfect car for the Karns track here in Knoxville. Love this car!
[QUOTE=tripthreat;9714768]The aluminum camber brace is more durable also. Going to the shorter link will make the front end much more aggressive, I really prefer the longer link. But as always, give it a try to see for yourself, then you will "know".
Thanks Frank.
Thanks Frank.
Suspended
Also could you ask the engineers why they chose smaller hexes for the front wheels, and why no droop screws?
i have 2 packs of these orings....
they look to be too small on the inner diameter.....
Kyosho ==> 3mm
Losi ==> 3.5mm
So these appear to be working for everyone?
You think the smaller ID keeps them from leaking and the material keeps them from binding?
Kyosho Shock Orings
They work great... I have them in my 22 shocks and they do not leak or cause any noticeable stiction.
Bumpsteer pt 2
Ok, so I never got to run my car "spindles up" last weekend and get to see the difference in.handling, but I just made the modification on one buggy only of mine while leaving the other buggy with the DE spacing. If you don't think bumpsteer is affected by this change, try this yourself.
On the stock setup, bumpsteer occurs (if at all) in the last 20% of travel only. In the spindles up configuration (and no change on bumpsteer spacer) bumpsteer occurs throughout the entire upward range of motion! Wow! I guess I was wrong about it only happening at the end of travel, but that was my understanding before. Maybe this slight bumpsteer angle change thru the whole range of motion is what smoothed out the steering response.
Physics, arent they great!
http://www.amainhobbies.com/product_...Shock-O-Ring-8
Back in my kyosho days I liked the clearn ones a little better. They felt smoother. The orange ones are a little more durable but I found they swelled faster then the clears as well.
