TLR 22 Racing Buggy Thread
#9001
Guys, i would like to have a neutral point a vue here. ... What will i gain or loose coming from a B4 to a TLR 22? I might change my ride
#9002
I am still having an ever so bothering binding in my front spindle/caster block region. I have tried red scotchbrite and spun the pin on my E driver and it polished it up and helped a little but still noticable on the arms/caster meeting point. Then I tried 320 grit sandpaper then the pad to smooth it out, just not as free as I feel is correct. I even tried a 1mm washer on the pin to have it not go so far into the caster block. What to do now? I don't have a metric drill bit set to match the mm's of the pin and I don't want to make it bigger than needed.
Overall the 22 is a great buggy. My first actually and I drive it better than anything I own or have owned. Still haven't broken anything.....well I have destroyed 2 wings... Very happy with it. Using most of the rough track setup from Charles Hicks on our rough, rutted 1/8 track. Thumbs up!
On a side note for the diff haters. Stock nut/holder, stock balls, sanded stock rings and Losi diff lube. 30 packs or so through it and it's baby butt smooth still. I keep it on the tight side and love it.
Ive been the go to guy for 22 concerns at my local track shortly after our track opened. Ive cured many 22's lol at my track and set the tq last wedneday night in mod. on our new layout. The main was a different story, and a well learned lesson/reminder about tires lol.
#9003
Not everyones experiences have been pleasant but ive gotten two people at my track re-buy 22's after seeing mine go around that track and leave there b4's behind.
Yes i know alot of it can be driver and set-up but i believe a 22 will make any experienced 2wd buggy driver faster.
just do some home work and build it right and dont let the diff slip, i run mine tight like all the tlr drivers say to.
Possible dis-advantages are what you gain in the corners you may loose in straight line traction. Ive found the 22 is a little more tire dependent but ive also ran some tires that are practically bald so it also depends on your set-up and surface( i run on a med at best to med-low grip clay track that is getting better and better) but with the right throttle application its not as big of a deal.
The advantage that the 22 offers that i found with my b4 when i was running it was it felt so on edge to go at pace that it was almost gauranteed that you would make a mistake where with my 22 i can sorta kick back and let the car do its thing and still run just as fast but if i need to run faster i can push the car and it takes it with ease.
All this talk makes me want to go wear out some tires
#9004
For those of you tuning experts, I've been spending a lot of my free time learning how the various aspects of tuning work, being a perfectionist, my goal is to get my car dialed enough that it'll just about drive itself. It's almost there. I'm trying to learn as much as I can without having to ask for help, I'd rather learn how to tune myself than rely on driver stup sheets for changes.
I started with the Dustin Evans setup, and have ever so slightly changed most aspects of it except for roll center, I can't quite grasp it. Does anybody have a quick explanation of how it works?
My car is nearly perfect for me right now, but adjusting roll center may be the finishing touch required to get my car perfect.
My set-up and your set-up are probablly pretty close, im running basically evans set-up again and only bouncing back and fourth between spring rates and possibly rear camber link between the two tracks i frequent. Oh and yeah im also running a long pack and it works.
#9005
I have built up 2 MM 22's for my friends and the Transmission has always felt buttery smooth when rotating the layshaft...
Building my own car last nite in RM config, and before i even started to bolt the gear box haves together i could feel a high spot in the gears as i rotated the layshaft. I tightened down the screws and no change. I double checked bearing placement and proper placement of the idler gear shaft.. no joy.... I fixed it by installing the other idler gear. My guess is one of the idler gears is not tru?? Has anyone experienced this? ITs the same sort of high spot my cougar had(that shummi explained in there instructions was totally normal for that car)
#9006
From a lot of what I am reading regarding handling setups I feel blessed! Built my car pretty much to stock specs and it handles great. Only thing I have done thus far is dialed in some more steering via my transmitter dual rate to about 70% and added some negative camber via the turnbuckles until I get some more caster blocks.
Hoping to make it to West Coast Raceway this weekend to see how it does in the JBRL...
#9007
needed to have the pack moved to the rear with the battery stop moved to the rear holes and the pack up against it, leaving only one foam pad to the rear of the battery compartment.
Had full rear traction at that point and needed to work on getting steering back which was the easy part.
#9008
I'm using a setup from our local Losi sponsored driver and the 22 sticks to the indoor clay track very well. The battery has 2 Losi foam pads behind it. I had tons of steering and plenty of traction.
Tires do matter and Calibers are not the answer to the tire question. I'm running red BK Bars in the rear and red Losi ribs in the front and I will need to trim/ghost the tires for racing, but the 22 did great even with full tread. I may also try a set of the new AKA ReBars super soft in the rear just to see if they do any better.
I'm happy to post this setup if anybody is interested.
#9009
Car works for me like this and never touch it between my 2 tracks, one hi bite clay and other mid to hi bite clay.
Tried small changes but always come back to this 100%.
Car jumps great, always did.
#9010
This is where I first put my short battery after changing from a long pack and the car was too hooked up in the rear, car pushed bigtime but when I moved the pack forward like the team guys (1 pad laid down and 1 upright) it was loose for me again, just like running the longer pack so I moved it back again and dialed in steering by going to HRC block, raising the spindles/lowering front of chassis and changing to 20* kick up while leaving the 5* caster.
#9012
After a couple of days at the track with the 22, I must say I am pretty pleased with the car. I did find myself needing more rear traction. Couple major changes recommended by a friend really helped lock in the rear; full fwd on the rear hubs and outer hole/middle row for rear outer ballstud. It was literally night n day difference in the amount of rear traction. This change helped me laydown the only other 16 lap qual (in our class) behind Eli Wed. night at SDRC
#9013
Thanks again, yeah I knew about adding the shim or getting the HRC anti squat kit. I'll be there tonight also so may hit you up for some info since I'm a super noob and need all the help I can get.
#9014
#9015
Maybe my question is pretty idiotic and I feel stupid but to measure camber do you have gauge parallel to axle of wheel or perpendicular to car longitudinal axis???
I am asking this because toe on buggy makes a big difference from setup sheets.
