TLR 22 Racing Buggy Thread
#7651
I’m looking for more forward traction coming out of tight 180’s on a somewhat loose outdoor track. I’m running the Evens setup which works great on the local indoor track but not so much on the outdoor track, the car is easy to drive just not that fast.
Anyone with suggestions on what to try first or what worked for them?
-Jeremey
-Jeremey
So to test, I would go down to 1mm limiters in the front, and drop all the way down to 0 anti-squat in the rear. Now, you may loose TOO much steering, which is ok as the test is to try and gain traction in the rear on-throttle... from there you could go back up to 1 deg antisquat if needed. But dropping to 0 will maximize rear weight transfer on-throttle.
Also, lighter oil in both front and back will increase the speed at which the weight transfer takes place. However, changing oil weight also affects how the car behaves right to left... and jumping... so that would be a later resort.
That won't help unfortunately. Rear droop only affects weight transfer to the FRONT of the car, OFF-throttle (entering a corner), and works in conjunction with front kickup. (opposite of anti-squat)
#7652
Looking to trade a very nice 8-T 2.0 for a 22.
I'm actually moving and where I am going, Nitro is pretty much dead.
http://www.rctech.net/forum/r-c-item...r-wtt-wts.html
#7653
So far I’ve tried moving the battery back, adding weight to the rear (in the battery compartment) and adding front droop (-2 turns). The only change that I liked was the added droop, I put the battery back and removed the weight.
Here are some of the things that I was thinking of trying for more forward traction.
- Adding more front droop (removing limiters).
- Lighter springs
- Lighter oil
- Moving the rear hubs forward
The tires of choice or DD’s or Hole shots
-Jeremey
- Lighter springs
- Lighter oil
-Jeremey
#7656
I have found my car to gain more forward bit the farther back I move the hubs. It also seems to smooth the car out throughout the corner. Making the corner more rounded and not so twitchy in and loose out.
#7657
- Lighter springs
- Lighter oil
-Jeremey
- Lighter springs
- Lighter oil
-Jeremey
-move lower shock mount to outside hole (may need to go down in spring)
-leave lower shock in inner hole and go up in spring
-add more pack to the shock
-lengthen the rear camberlink
-add more rear toe via the block(moving the hubs forward slightly adds toe but doenst really help forward bite, only makes the car act wierd in the center of the corner)
#7658
1) I gained straight line on-power rear traction, due to more weight hanging out the back of the car (which equates to less ON-throttle steering)
2) GAINED rotation neut-throttle AND off-throttle, due to shorter wheelbase.
#7659
I find that moving the rear hubs all the way forward gave me two things:
#7660
TLRacing
#7662
What difference is there going from 10 to 5 degree caster blocks?
#7664
had too quote it, thanks
#7665
Help with tlr diff
Hi guys iv read the sticky about rebuilding and setting the diff and slipper. But there is a point where i just cant get my head around it,
You have the diff in the car, and i tighten up tje slipper clutch. I hold the left wheel. And the slipper gear. Then turn the right wheel.
But what kind of tightness am i looking for. It goes from smooth, easy to turn , to not much harder to turn with some effort smooth. Which it just feels to loose. But the next stage of turning it gets stiffer to turn, but it has a slight grinding sound. But is stiffer to turn . So i go back slightley tp smooth turning again. But tje point betwen smooth and slight tight gind sound is so minimal, but the far end of smooth turn , just seems to loose. So am i suppose to have a tight turning with some kind of grind feeling , or should it just be only smooth, if so i feel its to soft to be right. I have ceramic balls in the diff.
Please help as its driving me mad and do not want to damage anything
Greg
Greg
