TLR 22 Racing Buggy Thread
#3767
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
got a pic? I havent heard of this happening but its quite possible.. did it happen when first screwing in the king pin or did you tighten it down then it cracked? or did it crack when trying to unscrew it?
I know my king ping screws are ridiculously hard to screw in
![Frown](https://www.rctech.net/forum/classic_images/smilies/frown.gif)
![Wink](https://www.rctech.net/forum/classic_images/smilies/wink.gif)
#3770
22 Build Tips:
8) Placing a very small amount of locktite between rear inner hingepin/hinge pin ball/aluminum pivots is a good way to keep the tolerances like new.
9) Do not forget the M3 screw hidden under the rear shock tower that goes into the rear camber block!!!!!!!!!!!!!!
I hope you all enjoy the build! Please ask any questions and I hope this info helps!
#3771
So in the kit build it says to install the front inner camber link to 2 but in the kit setup sheet it says 1.![weird](https://www.rctech.net/forum/classic_images/smilies/weird.gif)
I swear Kyosho had the best shocks, but these maybe my new favorite. Hope the orings stay smooth and consistant.
Diff does feel rough in your hand but once adjusted in the car it feels butter.
Anybody else notice the steering bump out under suspension compression?
#3774
#3775
unless you have a load of newly glued tires on AE rims, why would you want to use anything but the hex wheels? Hex wheels are of the future, I was surprised when I came back into this hobby a couple of years ago after being away from the game for over 15 years, that pins were still used on the rear rims.
Even if you do still have used AE rims, just get rid of them, as they are probably out of round anyway.
but yeah, you shouldn't have been driving an AE in the first place lol
#3779
What overall length are you running on the front/rear shocks..
Thanks,
Steve
Thanks,
Steve
