TLR 22 Racing Buggy Thread
TLRacing
I'm now putting together the parts list to apply the Frank Root Standard setup to my RTR, and did a search but can't find a definitive list. I've compared the stock RTR setup sheet to the Frank Root Standard setup sheet, and was wondering if I have it correct. So far I have:
Please can someone confirm if the below 2 are essential? From what I can see they are aluminium versions of the RTR parts that are in plastic, so are more of a durability upgrade with potential effect on weight?
Thanks in advance for your help.
- TLR1058 5deg castor block
- TLR1049 25deg front kick shim
- TLR2931 +.75mm rear spacer
- TLR5166 White Rear Shock Springs
- LOSA5253 25wt Shock Oil
- TLR1072 Aluminium Front Pivot
- TLR2060 Aluminium rear camber block
I just put the new 2013 setup on my car to try out. SO MANY WASHERS and screws!!!
Franks 2013 reedy setup?
TLRacing
I see in a lot of setups that 3 turns out in the rear shocks is very common. It seems at most, some people do 1 limiter. Does TLR plan to release a longer shock shaft for the rear? I only ask, because we used to unscrew the .71 fronts on the b4, but then AE released .80 shafts.
I was ordering the parts from the local hobby store here, and apparently someone came in the day before and purchased the same parts. Proof that your setup is bringing in the dollars to Losi. Seriously, thanks for helping us get our buggies dialled.
OK.. it worked.. its all free.. little sanding.. little loosening and all good..
OK next issue, need advice...
On the Rear Drive Shaft and Hub Assembly...
B-1
The rear plastic hex TLR2052 that goes over the outer drive shaft... It does not fit beyond the threads... It seems to me it should be pushed all the way up against the spacer/bearing.... Do I ream out the hex to make it fit? Do I force it?
Again thanks for the advice!
B-1
R/C Tech Elite Member
B-1
B-1
Anyone tried franks setups on outdoor wet/dry mixed tracks. seems like most people on here race indoor hard packed tracks. so hard to get good info on outdoor tracks.
Were those asking for clarification from me for my question about parts list? If so, I was referring to the "standard" setup sheet, and not the Reedy.
On a related note, not from personal experience, but the standard setup is what several local drivers have recommended I try for outdoor packed surfaces.
