TLR 22 Racing Buggy Thread
Tech Legend
Trader Rating: 51 (100%+)
I just finished building a 22SC and raced it for the first time. I liked it so much and loved the fit and finish I'm going to buy a 22 buggy in another couple of weeks.
Does the buggy come with the emulsion shock caps like my 22SC or will I need to buy then as an option? Not sure if Losi did a running change on the kit or not since everyone seems to run their shocks emulsion style. Just seeing what I need to get when I build the kit.
you have to buy them extra...i just use the plastic ones...
Tech Legend
I ran my with rear motor last winter. I ran panther tyres with additive, but anyway. To gain steering I ran bulldog bodyshell to star with, then you can either raise the front steering block or/and raise the camberlink at the wheel. I ran the brass shim in front as well. You can try to shorten the rear link to like 1D to loosen up the back. 3deg toe and low gearbox (not raised). Then of course you need to get the shocks and springs right. I ran orange with 40wt/55 in the back and 35wt/55 with blue up front. That all depends on the amount of traction.
V
gearing suggestions for my 8.5 or 7.5 motor suggestion
Hey i have been contemplating on buying a 7.5 for a while because mostly everyone here does and i like the power and speed of the 7.5 motors.Right now i have a tekin rs with an lrp x12 8.5 and i feel alittle slow on the straight aways on the outdoors tracks.Right now it is geared 25,76 and it comes barely even close to warm so im wondering if i should maybe change my gearing or just buy the 7.5.And if i did is there any suggestions for which 7.5 i should get,if i go with a new motor i want to stay with lrp,viper,or the new tekin gen 2.Thank you for any replies.
Associated diff/ thrust lube
Has anyone used Associated's STEALTH diff lube or their REGULAR diff lube which one would be suggested?
The TLR stuff is a little thick. IT makes setting the diff a little hard. Other then that it is fine. TLR black grease good and works well for lots of thing from the thurst bearings to CV joints or gear grease for metal gears.
R/C Tech Elite Member
running orion r10/8.5 combo what good gearing for a med/large track?
any esc help would be apreciated...also please.
Happy Thanksgiving to all of you. May you have a great meal and spend a lot of great time with family and friends this holiday!
Registered User
Anyone know where to buy these?
*sold out everywhere!!
Woohoo today my:
* AMB Transponder arrived.
* TiNitride Front King Pins
* 25* Brass Kick Shim
* Lots o Springs.
Buggy is going to be so dialed.
* Lots o Springs.
