TLR 22 Racing Buggy Thread
The xceleron 60c 3800 mah are my reccomendation.
I'm like 95% sure neither part in the stock steering rack kit is delrin. They are 2 different plastics that were "designed" to move freely and reduce wear. One of the only weak points of this car IMO, not that they break, just how fast they wear and how much they cost to replace
somebody was telling me that the reason that the rack wears so much is when you turn one way it puts upward pressure and when you turn the other way downward. If you shim the ball stud right you can knock out almost all of that angle and reduce the pressure. Sounds good in theory, but I have no idea if it works......
Personally i applaud the design, it doesnt bother me that it wears and i have yet to break one and like others have said, a standard bell crank set-up develops the same amount of slop.
My 22 that has been raced two or three times a month since fall is just a tight as my 22T with one race day. Except for the steering rack. Once it got sloppy I put in a new plastic slider and left the original C track. And it has stayed good since.
So the 22 wears fast like the 2.0 1/8 buggy? That's kind of a dissapointment. I said to myself I would never own another Losi cause of how fast they wear. But I went ahead and got a 22 cause I thought these 2wd would inevitably wear less. Hmmmm oh well Im gonna run the shit outta it regardless. I was told this buggy was the one to get, now if it would just get here lol
My thoughts exactly. I have tried both and had a B4 before I got my 22. I even loved the XXX. However, the TLR 22 is by far the better buggy out there. it just handles so much better than the others. All RC's develop some sort of slop over time as things just wear out. Some things wear faster than others. I accept that; especially when I have a buggy that performs to my satisfaction.
I just bought some Turnigy Lipos as well and expect good things based on what I have heard and seen at my local track.
For curiosity, I just finished a new Schumacher SV2 buggy.
This steering rack has no less than eight bearings in it's steering system. The rack was tight and smooth on the bench. I raced it one night. When I got home and checked the car over, the bearings all settled in and I found the one day old rack with as much slop/play as my 22 has currently with six months of hammering.
It's not an issue fellas, the rack is beautifully simple, elegant, effective, with little opportunity to fail - it only consists of two parts.
Expensive? What? The entire steering system is like $8.00? How much do you pay for a pair of inserts? A good pair of wheel bearings?
Don't obsess as I did early on...drive, enjoy and repeat.
Yes it is my first, but i got the chance to drive my buddies dex210 bfore i made the final decision to get a 2wd and he couldnt pry his remote from my hands it was that much fun. i think my experience was the exact opposite of how a 1/8 only driver would drive a 2wd
double post
That said, it's going to be immensely frustrating at first. There are 3 things to remember:
1 - Stay as smooth as possible. Start slow, but do everything you can to maintain control of the car, and stay on the fast line. Flying down the stright is great, but it's pointless when you barrel-roll through the next turn.
2 - Don't be afraid to change your setup. Practice and tune as much as possible (once you get the whole slow is fast thing down).
3 - Don't give up.
