TLR 22 Racing Buggy Thread >
Like Tree1Likes
Old 04-01-2012, 06:56 AM
  #15001
Trader Rating: 49 (100%+)
Originally Posted by jkirkwood
I had to buy 4 rear white springs sets to find a match. 3 rear yellow, fronts was within an acceptable tolerance.
How did you match the springs? Losi shock tool with no fluid in shocks?
aradaiel is offline
Old 04-01-2012, 07:44 AM
  #15002
CloseYetFar's Avatar
Hey I was on the track a day ago and I had both of my rear inner hub bearings collapse. I was able to replace them with no problem. I was told this is kind of normal as Losi bearings suck. Is this true or do I have a different problem?
Summary: Inner rear hub bearings crushed, outers are just fine.
CloseYetFar is offline
Old 04-01-2012, 08:01 AM
  #15003
rider313's Avatar
Trader Rating: 94 (100%+)
take a digital calliper and measure each spring off of the shock.
rider313 is offline
Old 04-01-2012, 10:40 AM
  #15004
Eli
Eli's Avatar
Trader Rating: 15 (100%+)
Originally Posted by slyts6
What tires would you all recommend for a rough, medium bite track??
It all depends, indoor? clay? wet or dry?
Eli is offline
Old 04-01-2012, 11:33 AM
  #15005
mtman75's Avatar
I would ask the other racers that are at the track and ask them or even ask the owners if need be.
mtman75 is offline
Old 04-01-2012, 12:43 PM
  #15006
Just a note, we're at the page 1001. Wow
lynx75 is offline
Old 04-01-2012, 01:06 PM
  #15007
Trader Rating: 77 (100%+)
I am just an average Joe behind the remote. I have been having issues getting the ball diff dialed in. From build to break in to setting it correctly. Well yesterday after much frustration someone at the track let me try his gear diff. Wow what a difference. For me this was the best thing I could have done. Now I will just play with the oil to get it fine tuned but for me this was awesome.
goin2drt is offline
Old 04-01-2012, 02:53 PM
  #15008
B00t13g's Avatar
In my bag I have super soft rebars and mc compound scrubs for upfront and soft square fuzzies, super soft hole shots and the softest gigabites. I run the fuzzies with rebars 99% of the time. This is on an indoor clay medium bite sometimes smooth sometimes rough and sometimes dry sometimes wet.
B00t13g is offline
Old 04-01-2012, 04:18 PM
  #15009
Jim Panebianco's Avatar
Thumbs up
I along with a few others are using Losi 2,000 diff oil in our geared diffs.
Jim Panebianco is offline
Old 04-01-2012, 04:28 PM
  #15010
Thanks for that. That is what is in it right now. I may try a little thicker next time out just to see how it drives.
goin2drt is offline
Old 04-01-2012, 04:44 PM
  #15011
B00t13g's Avatar
Try losi 4k and you won't regret it. With that said now that I can build a ball diff and have it last, there's no way will I go back to a gear diff.
B00t13g is offline
Old 04-01-2012, 07:39 PM
  #15012
Trader Rating: 37 (100%+)
It's dry, outdoor clay....
slyts6 is offline
Old 04-01-2012, 07:43 PM
  #15013
the wheel's Avatar
Trader Rating: 29 (100%+)
Default set up
guys i have been running the 22 for about 3 months now and i just can not get it to handle the way i want , it is really unforgiving,i have tried multiple set-ups and i just am not able to push this car ,it is very much a touchy car ,i have had frank roots set-ups on it ,dustin evans reedy set-up and i played with both and now i am working back to the stock set-up and it is a little better but still very touchy,any suggestions or is this the car itself or is it the set-up or just me, alittle help guys please i run 10.5 on a med to high bite tight track
the wheel is offline
Old 04-01-2012, 07:48 PM
  #15014
RShockley's Avatar
Where are you having issues with the car? Forward traction? Turns? Entry or Exit? On Power or Off Power? Or is it just bad everywhere?
RShockley is offline
Old 04-01-2012, 07:55 PM
  #15015
the wheel's Avatar
Default set up
it really is not great anywhere the rear is real snappy getting on power out of turns ,pushy off power ,and if you try to push it it gets slower and twitchy ,it is really hard to explain i guess
