Like Tree1Likes
B44.1 Thread
Old 10-19-2011 | 12:41 PM
  #796
RCmayor's Avatar
Originally Posted by Lonestar
Hey guys
I ran my 44.1 for the first time as part of the first race of our indoor local series. Last time I ran 4wd electric was last millenium
The stock spur has an obvious high spot, but I can uld live with that. Typical AE spur junk
The rear gearbox started developing a "tight" spot at the end of the 5mns of practice i ran the car for. I didn't have time to wrench on that the whole day as I was running both 2wd and 4wd the whole day, so I ran it like that, knowing it was suboptimal but hoping it would hold. It did but I spent most of the day tightening the slipper run after run, as the nut would unscrew all the time. Again, I haven't checked what shape the o-ring is in, but I suspect it's gone. During the last round of the A, which I still managed to grab, the spur ended up letting go at the same time as the slipper which went completely loose (bye bye o-ring).
had one of the local top dogs help me set it up with the diffs early in the day but obviously I did sthing wrong about it. I can set up a diff/slipper combo pretty well in 2wd, but 4wd was a bit of a new thing to me.
HEre's my Q - is there something special to do to this slipper to make it work, or to actually prevent it to work at all like mine did?
Paul
Ya, ended up blue thread locking the slipper nut. If that doesn't work I am going to thread tap for a set screw on one side. Just will have to loosen it for adjustments.
RCmayor is offline
Old 10-19-2011 | 02:19 PM
  #797
Jeauxkor's Avatar
Originally Posted by Ostach24
here is a picture of my 44.1, painted by myself... anyone interested in getting a body painted lmk
As far are set up goes, it depends on bite of track and how you drive. I know I hate sway bars, but they work for other people. stock set up is good, pretty sure I run that, but a little heavier weight in oil and I adjust the collars to where I want them depending on what tires I am running.
Very nice paint. How much do you charge?
Jeauxkor is offline
Old 10-22-2011 | 09:18 AM
  #798
johnbugman's Avatar
Default i just built 2 stage shock pistons from mantis
hi anyone try these out yet and any suggestions? I put 30 weight shock oil up front and 25 in rear. seems to be awesome on the bench so far. havent finished electronics yet to see the real deal. any suggestions comments.
johnbugman is offline
Old 10-23-2011 | 05:14 PM
  #799
TJMac's Avatar
Default Crazy brain fart....
Has anyone tried the Mini MGT metal gear diffs in the B44.1? I don't NEED them, but it would be cool just to see if it works.
TJMac is offline
Old 10-23-2011 | 06:29 PM
  #800
vicdamone11's Avatar
how do I get a little bit more on power steering? Should i loosen the diff a litting bit? Im running the maifield set up right now and its perfect, super fast, its got great high speed and turn in steering, it only pushes a bit too much for my liking when exiting the corner and getting on power.
vicdamone11 is offline
Old 10-31-2011 | 06:55 PM
  #801
I just rebuilt my diffs for the first time and my friend said I should have also bought a couple of the longer T-nuts from the NTC3 (I had to reuse an old one). What are the actual part numbers we should be using? Should it be a TC3 or an NTC3 rebuild kit? Also, in one of the two TC3 rebuild kits there was a short T-nut in the bag and in the other there was also a long one (that is, both long and short). Is this normal or was it a mis-packaged fluke?
EricJ is offline
Old 10-31-2011 | 08:08 PM
  #802
How does 44.1 compare to the durango buggy, i know 44.1 is world champ but how does it do on the club level??
rickybobbyxxx is offline
Old 10-31-2011 | 08:44 PM
  #803
Honestly the best driver wins. At our track they are just so easy to drive and control that you put the best driver with any 1/10 scale 4x and he is going to win. IMO. I would buy what the rest of the folks drive at your track so you can borrow broken parts
goin2drt is offline
Old 10-31-2011 | 09:01 PM
  #804
haha everyone get a different buggy im tired of supplying arms and shock shafts haha jk i want everyone to run the 4wd with me even if i have to give out parts... pretty sure I am wiped out now.
Ostach24 is offline
Old 11-01-2011 | 12:52 PM
  #805
sc3tech's Avatar
i was having trouble with a used battery i bought and now im looking for a new saddle pack.. Would it be safe to run a 35c battery with my set up? Tekin rs pro with a lrp 6.5turn motor. Geared pretty low at 18. Or should i be buying 50c batteries?
sc3tech is offline
Old 11-01-2011 | 12:56 PM
  #806
6.5 you should have tons of power. if it feels slow just go up on pinion
Ostach24 is offline
Old 11-01-2011 | 01:07 PM
  #807
sc3tech's Avatar
no the power is good. the pack i bought was puffing. Im just in the market for another saddle pack. I geared it low to keep temps down and learn more control with the car.
sc3tech is offline
Old 11-01-2011 | 01:33 PM
  #808
crashnburn's Avatar
What size pack are you running? 5000, 4850, 2600??? It does make a difference....
crashnburn is offline
Old 11-01-2011 | 01:36 PM
  #809
I meant if you went to a 35 c lipo... depends on what c rating you are coming from. there is a difference between them, I was just saying if it feels slow with a 35c just go up on the pinion. And packs always puff a little. I am not sure the cause of it, but they still work fine. I have Never seen a lipo problem unless the esc caught on fire and took the lipo with it
Ostach24 is offline
Old 11-01-2011 | 01:46 PM
  #810
sc3tech's Avatar
this pack wasnt puffing a little.. it was completely coming apart. and wouldnt fit in my b44.1 anymore. But okay i understand what your saying. I already have a 50c saddle pack and it rips. I was just debating if i should buy another one or save some money and buy a reedy saddle pack @35c 4200. theyre only 62 on amain
sc3tech is offline
