Like Tree1Likes
B44.1 Thread
Old 06-03-2012 | 01:41 PM
  #2296
Mini8 Menace's Avatar
Default thanks man
Originally Posted by rigor
Had thought about this exact thing. Glad to hear it works. Nice job.
I've been running the foam for about two months and the stock screws slots are fine still and no slap on the 1/8th scale track and thats where i mostly run i figured i'd put it up here since i hear this problem all the time but it is deff a great lil trick
Mini8 Menace is offline
Old 06-03-2012 | 03:41 PM
  #2297
EvanAZ's Avatar
getting a couple BJ4 buggies, and was told the parts are interchangeable with the B44.
is this correct?
They will be used in our kids rc program, and really don't want to have to try and source parts.
EvanAZ is offline
Old 06-03-2012 | 04:54 PM
  #2298
aeRayls's Avatar
For the most part the parts are not interchangeable.! They have small differences that make it difficult to make them fit. The only things I remember that direct fit are, shocks, rear hubs. The major parts and the stuff that breaks regularly do not transfer over.
aeRayls is offline
Old 06-03-2012 | 05:38 PM
  #2299
rigor's Avatar
is this correct?
Don't rely on the parts being interchangeable. B44 parts aren't carried quite as widely or deeply in stock too compared to a B4.
rigor is offline
Old 06-04-2012 | 02:50 AM
  #2300
racene1's Avatar
I have a few extra sets of the tlr 22 front rims and i was wondering if they would fit my B44.1? (i know the hexes will but has anyone tried them for the offset)
thanks
JT
racene1 is offline
Old 06-04-2012 | 08:28 AM
  #2301
targetingxmod's Avatar
thanks
JT
For what i read they will fit, but don't know abou the offset to!!
anyone?
targetingxmod is offline
Old 06-05-2012 | 02:19 PM
  #2302
vicdamone11's Avatar
Anyone have a good carpet set up. Everythin I see is for turf.
Thanks.
vicdamone11 is offline
Old 06-07-2012 | 09:36 AM
  #2303
Grouchman's Avatar
Can't wait for the Jconcepts wing mount to be released......
http://www.thebigrc.com/?p=2897
My B44.1 really needs this!!!!!!
Grouchman is offline
Old 06-08-2012 | 05:15 AM
  #2304
blown sv's Avatar
They have been , you can buy them on the jconcepts web site .
Guys a need to know if any parts are needed to fit kyosho bb springs , are the AE collars big enough?
Cheers
Chad
blown sv is offline
Old 06-08-2012 | 05:55 AM
  #2305
MiCk B's Avatar
Cheers
Chad
Hi,
You need big bore collars and spring cups for the BB springs on the AE shocks,
Something like this:
GHEA 2070 BB spring collars.
Or the Avid versions:
Link
For spring cups the Losi 22 or the Durango BB spring cups fit.
MiCk B. :-)
MiCk B is offline
Old 06-08-2012 | 07:22 AM
  #2306
racer_guy's Avatar
so here is the deal. my 44.1 is still a virgin. getting everything else i need for it to run this weekend. i hear alot of yall talkin about extra shims on the tranny's. shol i just get some more shims and do it before i run it for less headaches or what? thanks in advance
racer_guy is offline
Old 06-08-2012 | 07:40 AM
  #2307
Asharus's Avatar
i havent had any issues w/ the stock shim setup. but a pack of shims is good to have for sure.
Asharus is offline
Old 06-08-2012 | 07:56 AM
  #2308
rigor's Avatar
Buy the shims now and make sure there is NO side to side play / movement of the outdrives, especially the rear gearbox. If It's not shimmed right, you ruin the bevel gear and need to replace it. Pick up an extra bevel gear set too in case.
rigor is offline
Old 06-08-2012 | 07:58 AM
  #2309
Asharus's Avatar
yes, always have 2 gearsets handy in your pitbox
Asharus is offline
Old 06-08-2012 | 08:03 AM
  #2310
rigor's Avatar
I've found 2 shims one the side as the manual suggest, and 6 shims on the bevel gear side (instead of 4) worked best for me. Have the gear mesh be tighter rather than looser if in doubt, otherwise you'll strip the gears. I went through a few gear sets myself figuring this out
rigor is offline
