B44.1 Thread
#2313
Avid collars just came out as well. My LHS got em Wednesday this week. They screw and bolt on over the stock AE collar. I like em.
http://www.avidrc.com/product/5/acce...ccesories.html
#2316
gone with the avid collars and losi cups
#2317
Can't wait for the Jconcepts wing mount to be released......
http://www.thebigrc.com/?p=2897
My B44.1 really needs this!!!!!!
I don't need to lower my wing that bad. I was hoping for plastic. The way I drive that aluminum wing mount would be absolutely destroyed in one race weekend
#2318
Ok guys, a question from left field. I've been racing the B44.1 for a few months now, Is it comon for the rear suspention in these things to not have a lot of spring back ? I'm still running stock setup, but the ass end sits down, and if you push down on it, it doesn't spring back very high, not even to level arms if it is just sitting there. It handles fine imo. When you brake hard the ass end doesn't try climbing up, it stays pretty level. The front ent moves up and down freely, but the ass end stay's pretty nuetral. Is this fairly common. Just wanna know if I should be trying to fix something, or winding the collars down a bit. What of it's driving characteristics would this be affecting. In my mind, if I got the ass end to be a bit more springy by wind down the collars it might allow for a bit more on power steering before understeer kicks in.
Now I think of it this was pretty silly question. Was set in my head that I wasn't going to change any settings until I was happy with my driving and that my ability matched what the stock setup had to offer. While reading the manual again, I read that the ride height should be adjusted to suit once the suspention had settled. So my next question is - is this adjustment always going to need tweeking further and further down the older the springs get, and is there a point that the springs are sprung and should be replaced. And if I broke a shock shaft and lost a spring, would I have to replace both springs so that they had the same spring characteristics.
This should also explain why I have worn the inside of the rear tires first, and correcting the ride height should see the set camber be operating in it's desired position and give me a more even wear across the tire.
#2320
and check thet the Suspension go very freely without any jammed...
if its all free, then check the shocks,Probably you need to change the oil if you didnt do that for few months, the shock oil burn out with alot of dirt in it.
that's make the shock work's not proper.
another thing, Always check the Ride height with ride height gage.
#2321
Well true for the parts for going BB springs, But some people lookng for big bore shock bodies, and associated is working on full bb shocks kits for the rest fo the 1/10th scale line up.
#2322
#2323
Anyone have a direct contact to STRC, I have a broken steering rack and only need a single part and don't want to order another complete kit.
It's going on 2 weeks with multiple attempts at contacting on their site and at customer service at strc.com
Still NO REPLY...
Still NO REPLY...
#2324
Anyone double up the rear shock tower ? Is it even possible with the way the rear the rear shock mount braces into the rear gear box ?
Pretty certain why sustained damage and consequently broke after getting a good hit from a SC driver not paying attention
1Likes
