Like Tree1Likes
B44.1 Thread
Old 10-07-2011 | 10:07 AM
  #736
sparkwraps's Avatar
From what I was reading, the newer cab-forward designs leave the wing way up high when the back half off the body is substantially lower. So aerodynamically, you are geting the full effect of the wing even though it is sitting a tad lower. With a standard body, you would loose downforce from the wing.
In theory, you will not notice a change in driving behaviors. So is it needed? Nope. I think it looks better though.
sparkwraps is offline
Old 10-08-2011 | 11:13 AM
  #737
Yeah I don't think you will really notice a difference in the bodies or the wing, but I noticed in 2wd that I lost a lot of rear traction when I dfropped the wing.
I think in mod you would probably notice it more at higher speeds.
With that being said I'm consider getting rid of my 44 or 44.1. Both are in prestine condition and only run on carpet. Let me know if anyone is interested. Also will come with either two clear bodies or two custom bodies, your choice.
Ostach24 is offline
Old 10-11-2011 | 09:18 PM
  #738
sc3tech's Avatar
Got in my order from tbone racing today, front and rear bumpers.. i must say im pretty impressed. Im only worried that there isnt much flex in the bumpers but they fit quite nicely and hopefully they protect the front shocks better
sc3tech is offline
Old 10-11-2011 | 09:21 PM
  #739
ABN Hoosier's Avatar
Can you post some pics please?
ABN Hoosier is offline
Old 10-11-2011 | 09:26 PM
  #740
vicdamone11's Avatar
Just finished up my build, went really smooth. I cant wait to run it this weekend.
vicdamone11 is offline
Old 10-11-2011 | 09:32 PM
  #741
nice paint
Old 10-11-2011 | 10:08 PM
  #742
paint is looking pretty good there.
Ostach24 is offline
Old 10-11-2011 | 10:23 PM
  #743
Thanks guys, a buddy of mine here in chicago does them for me. Its got a matching under tray pretty sick ill take a better shot of it when im at the track. That black is all carbon fibre, u cant tell with that pic.
So is everyone pretty much running the ballast weight? im going to just try it with out it at first. I built it according to the Lipo Setup.
Old 10-11-2011 | 10:26 PM
  #744
I dont run the weight, I am a fan of keeping everything as light as possible. I also dont like the sway bars either though, but I run on high grip, so my tastes might be a little different than yours
Ostach24 is offline
Old 10-11-2011 | 10:42 PM
  #745
Dadaman's Avatar
I used them and every time the buggy went over a jump, the front would dig into the ground and flip it. IMO, the bumpers are not bent up enough closer to the shocks, but rather sit down to low. I tried both front and rear and just had the problem with the front one.
Dadaman is offline
Old 10-12-2011 | 08:30 AM
  #746
I'm sure it would protect the front end from collision, but they just look weird to me.
Ostach24 is offline
Old 10-12-2011 | 08:32 AM
  #747
build is going well . straight forward . not sure what I want to do with my electronics . I have a MMP and a Novak Havoc and a 1410 Castle Motor and a8.5 Novak Ballistic Motor . I am open to buying something new . Probably end up with a 6.5 Novak ?? I really like my LRP speedo in my B4.1 . I might pick up another one of those .
What LRP speedo would be good for this buggy ?
Kenton is offline
Old 10-12-2011 | 08:39 AM
  #748
U can run the comp or tc. Only differences between those two are the fan andd heat sink. I'd stay with the 8.5 it will be plenty of motor unless you're running on a HUGE track.
Ostach24 is offline
Old 10-12-2011 | 08:52 AM
  #749
Thanks for the input . I will try the 8.5 since I have one . But most of the top guys at my local track are using a 6.5 so I will eventually end up there I think . Nice to know that a 8.5 will get the job done . Really do not want to buy another motor right now . I still need to buy the servo and and a couple saddle packs for it .
What Saddle Packs will fit in this buggy ? Will the Pro Match 5200 mAh 50 c fit ? I want to get a LiPo with a c rating of 40 or higher . DO not want to break the bank , but do not want to buy from HobbyKing either .
Kenton is offline
Old 10-12-2011 | 09:26 AM
  #750
I run thunder power or smc. The smc has less power, but still does just fine. Also I know we all say see what the guys are running at the track to get a baseline, but you have to know what you can handle as well. A lot of Guys at my track can run a 17.5 within a second of some of the mod guys, but when they run mod they run slower times because they are not used to the speed and cant handle the power.
Ostach24 is offline
