Like Tree1Likes
B44.1 Thread
Old 09-28-2011 | 10:43 AM
  #721
13.5 would probably be enough at this track. I run at this track pt raceway http://www.youtube.com/watch?v=NQLuG...470BB628D0F155 and you can check out the video page. For most guys fastest needed is a 13.5. it is pretty small and on carpet. I run a 10.5 and it is plenty fast, stays cool and I even turn it down to 90% epa on futaba radio to keep in control.
Ostach24 is offline
Old 09-28-2011 | 10:44 AM
  #722
Midnight's Avatar
Originally Posted by djbclk430
8 -10 min i tried putting holes in the body i will try a fan on the motor what motor r u running with stock spur and 19-20 pin?
Tekin 8.5
Midnight is offline
Old 10-04-2011 | 07:06 AM
  #723
kyle3333's Avatar
Has anyone tried the lowered wing mod that Brent Thielke was explaining at the Indoor Nationals in Mass. this past weekend?
The video is really shitty, so it was tough to see exactly what he was talking about. Apparently you take B4 wing mounts and a B44 battery post and I don't know from there.
http://www.rccaraction.com/blog/2011...oor-nationals/
kyle3333 is offline
Old 10-04-2011 | 10:02 AM
  #724
TJMac's Avatar
That is quite possibly the worst video I have ever seen online.....well done RC Car Action .
I'd also like to know how to do this mod.
TJMac is offline
Old 10-04-2011 | 10:22 AM
  #725
kyle3333's Avatar
Hahaha!!! Tell me about it.
kyle3333 is offline
Old 10-04-2011 | 10:37 AM
  #726
kyle3333's Avatar
A friend sent me this picture just a minute ago. You need B4 wing mounts, longer screws to go through the shock tower and bulkhead, and a b44 battery post. I don't know how many slams this wing configuration can take, so if you have difficulty keeping you car right side up, I don't think I would recommend this mod to you. Enjoy!
kyle3333 is offline
Old 10-04-2011 | 10:40 AM
  #727
sparkwraps's Avatar
Looks like you just use the B4 wing mounts and the battery post is used to go between the two mounts, where the transmission sits on the B4.
Terrible video, but the mod seems pretty easy.
Maybe I am missing something?
A minute to late... what Kyle said!
sparkwraps is offline
Old 10-06-2011 | 01:28 PM
  #728
RCmayor's Avatar
I was looking at the stock mounts and how they could be modified to do the same thing. This is how it turned out.
RCmayor is offline
Old 10-06-2011 | 01:37 PM
  #729
RCmayor's Avatar
You just cut the bottom of the mounts off, don't take too much off, do a little at a time until it sits flat on the tower mount. The aluminum piece between is 20.2mm. You will see a couple of round mold marks in the mount, drill a hole in the center of each of those and then screw it together. Drill out the holes in the tower mount so a screw will slide through the mount, that way it will tighten properly.
One thing I didn't do yet but might if the screws pull out is to drill a hole so a small 3/16" nut can be slid in for the mount screws can have a little metal to bite into.
RCmayor is offline
Old 10-06-2011 | 10:23 PM
  #730
Default I am in
I am in dudes . Just picked a new B44.1 today . Any tips for the build that I should know about ? What motor and ESC are you guys running ? I have an extra MMP and 1410 motor . Would that be to much ? Is a sensored motor the way to go with this buggy ? What parts should I stock up on ? I am thinking front arms . Any other tips for running this buggy ? I am so stoked !! Sold my 4x4 SC truck and 1/8th scale buggy to get the B44.1 . I am planning on running a XP1015 Servo . Will that be a good choice ? I will be running at a large indoor track . OCRC in So Cal . Thanks in advance for any help !!
Kenton is offline
Old 10-06-2011 | 11:26 PM
  #731
to me it doesnt really look like this mod would do anything but give you less rear downforce/rear traction. I know in 2wd when I dropped the wing down on the rb5 there was less rear traction.
Ostach24 is offline
Old 10-06-2011 | 11:28 PM
  #732
another way to get the same end result is to cut the wing a little more in the back. jcon had 2 maybe 3 lines for the height of the back of the wing. If you just cut it lower so less air comes through you will get less rear traction. a lot easier than to cut your mounts and attach a batter post to it.
Ostach24 is offline
Old 10-06-2011 | 11:34 PM
  #733
LRP 7.5 motor with an MMP speedo.
TeamOSG is offline
Old 10-07-2011 | 07:29 AM
  #734
Thanks for the advice . I have the MMP ESC already , I also have a 8.5 turn ballistic motor . Maybe I will try that ?
I am suprised you reccomended the MMP ESC . And not a LRP or Tekin or Novak even . IS that what you are running ?
Kenton is offline
Old 10-07-2011 | 08:49 AM
  #735
RCmayor's Avatar
Ya, I'm not sure what the overall effect will be. Was just looking for a better way of doing it rather than using B4 mounts. This way has better support for the wing since it is not just floating off the 2 screws.
RCmayor is offline
