Like Tree1Likes
B44.1 Thread
Old 07-20-2011 | 11:52 AM
  #451
Originally Posted by 19quiz76
Shock ends are spot on.... shafts...not sure check your manual
IMPACTPLAYR is offline
Old 07-20-2011 | 11:54 AM
  #452
Originally Posted by IMPACTPLAYR
Would a center one-way for the NTC3 work on a B44, and if so would it allow the car to act more like a 2wd in the air?? obviously when you apply throttle in the air it will still bring the nose up fast, but will the front still dive as bad when you let off the throttle to much?? everywhere else on the track the car is golden to me.. so I don't wanna change the set-up too much...
Anyone have any idea on the Ntc3 center one-way fitment?
Old 07-20-2011 | 02:09 PM
  #453
How would you brake?
EricJ is offline
Old 07-20-2011 | 02:16 PM
  #454
Originally Posted by Buckaroo
Gens Ace saddle pack, click hereCheck out the Gens Ace saddle pack. Great pack, awesome price.
Cool! I'm a huge Gens ace fan got 4 sticks from them.
GuiltyByAssoc is offline
Old 07-20-2011 | 02:20 PM
  #455
What's to think about?!? I don't even want to say what I paid for mine, now..
No doubt, one day soon I should have a b44 xxxx. Just got a sc10 4x4 so after its up and running/crashing I'll start seriously doing some homework on the 44..
Old 07-20-2011 | 02:21 PM
  #456
big chris's Avatar
That's the rear shock shaft. You need # 9723 for the fronts. Rod ends are correct. May need some spring cups also in case of a break and you can't find it on the track. # 9724
big chris is offline
Old 07-21-2011 | 12:33 AM
  #457
The center one-way is for the front gearbox, not where it attaches to the spur, so the front wheels do not brake only accelerate, the rear wheels still brake...
Old 07-21-2011 | 08:15 AM
  #458
Lonestar's Avatar
Cool - thanks guys
Paul
Lonestar is offline
Old 07-21-2011 | 09:03 AM
  #459
Default RPM dual stage shock pistons
Hello everyone. I recently purchased a B44.1 to get into racing at my local track. I bought some RPM dual stage shock pistons. Anyone else tried these? I will install them this weekend to see how they affect my buggy. I couldn't find any info on them in the b44 thread or this thread.
bbeckstrand is offline
Old 07-21-2011 | 09:06 AM
  #460
davidfast's Avatar
This should help: http://www.rpmrcproducts.com/faq/pistons.htm
I've used them in my 2wd cars quite a bit.
davidfast is offline
Old 07-24-2011 | 08:28 PM
  #461
Default Need help
So here it is. I run the same track every week (high bite clay). My set up is dialed (or was). Here is the issue. When the track is freshly watered the car is dialed.
The problem is if my heat is later and the track starts drying out the rear end is super loose. Not just a little loose but a whole different car.
Is there something minor that can get changed based on the track conditions that can quickly go back and forth between?
Hopefully this makes sense.
goin2drt is offline
Old 07-24-2011 | 08:32 PM
  #462
Are you running a rear swaybar with your setup?
Rocky8333 is offline
Old 07-24-2011 | 08:36 PM
  #463
Yes
goin2drt is offline
Old 07-24-2011 | 08:39 PM
  #464
Yes
Scratch that then...
Try playing with different compound tires if nothing else. If you are losing rear traction, it could be remedied by changing to a harder/less agressive front tire, or by going all around to a softer tire compound. That's the quickest thing I can think of.
Old 07-25-2011 | 12:37 AM
  #465
gee-dub's Avatar
Default New (?) Front Springs
I was just watching the IFMAR 4wd post-race conference and Cavalieri mentioned going to a "little bit stiffer spring in the front". Looking at pics and video throughout the event, the fronts have always been silver which I assumed were the 3.85/#6496's (i.e. part of the standard setup). Unless today's fronts were stripped blues 4.20/#6497, they don't appear to be cut truck fronts or rears, this would mean there is a new spring in existence.
Anyone have knowledge about a new spring and/or was this a custom part? Thanks in advance.
gee-dub is offline
