B44.1 Thread
#481
hey guys i just picked up a used b44.1 with a spektrum s6040 servo and lrp x12 vector 6.5t motor. what do you recommend for a rx/tx combo and most importantly a good esc? thinking about castle or lrp but so many options.
#482
I'm running a speedpassion. They are on sale right now for $99. Works just as well as my tekin pro. The prostock will handle down to a 5.5. If u wanna spend a little more, u can get the pro for $125. I have both, which is working great so far for me.
#483
Could anyone recommend a budget solution, I don't want to put too much $ into this until I know for sure I want to stick to 1/10, and not give into the urge to go 1/8..
Also - it doesn't seem to be a designated space for the rx and esc, where did you guys place them and how did you fasten them?
#484
It seems like the servo from the Strike is too big to fit into the B44 - do I need a new one?
#485
#486
thanks for the info. ill definitely look into that
#487
I see that A Main has like 29 different Savox servos - are they all the same size so they will all fit the B44?
#488
No... stick to either the 1257TG or 1258TG which are standard size servos. Savox makes High output, mini, micro, large-scale, etc. The two I listed are the best for this application. 1257TG is plenty, 1258TG has a little more torque and a slight increase in price.
#489
#491
That's a decent one. It has the metal gears so it will last a while, and the torque is sufficient. The Difference is the transit speed. I use the 1257TG because of the 0.07 transit time which gives a real connected feeling for the driver. The 0252 has a slower speed, but not so bad it hampers driveability.
#492
Mine has a somewhat different layout with all the electronics behind (or on top) of the servo and the only wires crossing the drive shaft go to the motor...
#493
1Likes
